SimulationPath provides intelligent path-based transport routing for material handling units in automation systems. More...
| virtual void | DrawPath () |
| virtual void | AttachTo (SimulationPath path) |
| void | OnMyStartSnapped (SimulationPath path) |
| void | OnMyStartUnsnapped (SimulationPath path) |
| void | OnMyEndSnapped (SimulationPath path) |
| void | OnMyEndUnsnapped (SimulationPath path) |
| void | TransportableEntered (PathMover trans) |
| void | TransportableOnEnd (PathMover trans) |
| void | TransportableExit (PathMover trans) |
| void | CheckSnapping () |
| void | ClearConnections () |
| void | AttachPathLine (string path, GameObject attachto) |
| void | AttachPathCurve (string path, GameObject attachto) |
| void | CheckSnap () |
| void | Connect (SnapPoint ownSnapPoint, SnapPoint snapPointMate, ISnapable mateObject, bool ismoved) |
| void | Disconnect (SnapPoint snapPoint, SnapPoint snapPointMate, ISnapable Mateobj, bool ismoved) |
| void | Modify () |
| void | AttachTo (SnapPoint attachto) |
Public Member Functions inherited from realvirtual.BasePath | |
| float | GetLength () |
| Gets the length of the path. | |
| Vector3 | GetPosition (float normalizedposition, ref BasePath currentpath) |
| Gets the position in World coordinates of the path at the defined normalized position. | |
| Vector3 | GetDirection (float normalizedposition) |
| Gets the tangent of the pat at the defined normalized position. | |
| Vector3 | GetLocalDirection (float normalizedposition) |
| Gets the direction tangent in local coordinate system. | |
| Vector3 | GetAbsPosition (float abspositon, ref BasePath currentpath) |
| Gets the position in global coordinate system at absolute position (in meters) at the path. | |
| Vector3 | GetAbsDirection (float abspositon) |
| Gets the direction tangent in global coordinate system at absolute position (in meters) at the path. | |
| Drive | Drive |
| drive used on the simulation path | |
| bool | DriveNotNull |
| PathStrategy | PathStrategy |
| Path strategy which defines the behavior at certain path events. | |
| List< SimulationPath > | Predecessors |
| List of predecessors, is filled automatically. | |
| List< SimulationPath > | Successors |
| List of successors, is filled automatically. | |
| SimulationPathEvent | OnPathEntered |
| List with methods called when a path mover enter the path. | |
| SimulationPathEvent | OnPathEnd |
| List with methods called when a path mover reach the end of a path. | |
| SimulationPathEvent | OnPathExit |
| List with methods called when a path mover exit the path. | |
| float | Length |
| Length of the path. | |
| bool | ShowPathOnSimulation |
| Boolean specifying whether the path is visible during runtime or not. | |
| float | Thickness |
| Thickness of the simulation path. | |
| Material | MaterialPath |
| Material of the simulation path. | |
| float | SizeDirectionArrow |
| Size of the direction arrow in the center of the path. | |
| GameObject | StartPoint |
| GameObject | EndPoint |
| bool | EnableSnap |
| bool | movedlocally |
| bool | transformposchanged |
| virtual void | LengthChanged () |
| void | SetStartTo0 () |
| void | DrawArrows () |
| void | BaseReset () |
Protected Attributes | |
| LineRenderer | Linerenderer |
| bool | blockdraw |
| Arrow | _startarrow |
| Arrow | _endarrow |
Properties | |
| Vector3 | LocalStartPos [get, set] |
| Vector3 | LocalEndPos [get, set] |
| Vector3 | StartPos [get, set] |
| Vector3 | EndPos [get, set] |
| OnSnappedEvent | OnSnapped [get, set] |
Properties inherited from realvirtual.ISnapable | |
This abstract class implements sophisticated path networks where MUs (Material Units) follow predefined routes through production facilities, warehouses, and assembly lines. Features automatic path snapping for network building, customizable path strategies for decision making at junctions, and event-driven control for station integration. Supports both linear and curved path segments with seamless transitions, enabling complex intralogistics scenarios like AGV routes, overhead conveyor systems, and flexible manufacturing system layouts.
◆ AttachTo()
| void realvirtual.SimulationPath.AttachTo | ( | SnapPoint | attachto | ) |
Implements realvirtual.ISnapable.
◆ CheckSnap()
| void realvirtual.SimulationPath.CheckSnap | ( | ) |
◆ Connect()
| void realvirtual.SimulationPath.Connect | ( | SnapPoint | ownSnapPoint, |
| SnapPoint | snapPointMate, | ||
| ISnapable | mateObject, | ||
| bool | ismoved | ||
◆ Disconnect()
| void realvirtual.SimulationPath.Disconnect | ( | SnapPoint | snapPoint, |
| ISnapable | Mateobj, | ||
| bool | ismoved | ||
◆ Modify()
| void realvirtual.SimulationPath.Modify | ( | ) |
◆ Drive
| Drive realvirtual.SimulationPath.Drive |
◆ Length
| float realvirtual.SimulationPath.Length |
Length of the path.
◆ MaterialPath
| Material realvirtual.SimulationPath.MaterialPath |
◆ OnPathEnd
| SimulationPathEvent realvirtual.SimulationPath.OnPathEnd |
◆ OnPathEntered
| SimulationPathEvent realvirtual.SimulationPath.OnPathEntered |
◆ OnPathExit
| SimulationPathEvent realvirtual.SimulationPath.OnPathExit |
◆ PathStrategy
| PathStrategy realvirtual.SimulationPath.PathStrategy |
◆ Predecessors
| List<SimulationPath> realvirtual.SimulationPath.Predecessors |
◆ ShowPathOnSimulation
| bool realvirtual.SimulationPath.ShowPathOnSimulation |
◆ SizeDirectionArrow
| float realvirtual.SimulationPath.SizeDirectionArrow |
◆ Successors
| List<SimulationPath> realvirtual.SimulationPath.Successors |
◆ Thickness
| float realvirtual.SimulationPath.Thickness |
Property Documentation
◆ OnSnapped
getset |
