PathMover enables intelligent autonomous movement of material handling units along complex path networks. More...
| void | OnSourceCreated () |
| void | Stop () |
| void | Start () |
| void | Stop (bool stop) |
| void | Block (bool blocked) |
| void | SelectNextPath (PathMover pathMover, ref List< SimulationPath > Pathes) |
| void | StationEntered (BaseStation station) |
| void | StationWorkStarting (BaseStation station) |
| void | StationWorkFinished (BaseStation station) |
| void | StationExit (BaseStation station) |
| void | SetPosition (float Positon) |
| void | ReleaseFromPathEnd () |
| void | SetToPath (SimulationPath NewPath, float SetPositon) |
| void | SetVelocity (float Velocity) |
| void | OnCreated () |
| bool | TryMoveNext () |
| void | RemoveFromPath () |
| SimulationPath | CreateOnPath |
| bool | LeavePath |
| bool | AlignWithPath |
| true if the chainelement needs to align with the chain tangent while moving | |
| float | Distance |
| float | DistanceSides |
| float | AngleSide |
| bool | DrawRay |
| Vector3 | AlignVector |
| additinal rotation for the alignment | |
| BaseStation | CurrentStation |
| current station the path mover is in | |
| BaseStation | CurrentStationWorking |
| contains a value, when the current station starts working on the path mover | |
| bool | IsStopping |
| true when the path mover slow down to stop | |
| bool | IsStarting |
| true when the path mover accelerate to target speed | |
| bool | IsStopped |
| true, if the path mover fully stopped | |
| bool | IsBlocked |
| true, if the path mover is blocked | |
| bool | IsOnPathEnd |
| true, if the path mover freach the end of a path | |
| SimulationPath | Path |
| Drive where the chain is connected to. | |
| float | Position |
| Current position of this chain element. | |
| List< SimulationPath > | NextPathes |
| SimulationPathEvent | OnPathEntered |
| < contains the following path of the path mover | |
| SimulationPathEvent | OnPathEnd |
| Event when the path mover reach the end a path. | |
| SimulationPathEvent | OnPathExit |
| Event when the path mover leaves a path. | |
| SimulationPathEvent | OnStopping |
| Event when the path mover start slowing down to stop. | |
| SimulationPathEvent | OnStopped |
| Event when the path mover fully stops. | |
| SimulationPathEvent | OnStart |
| Event when the path mover start accelerate. | |
| SimulationPathEvent | OnFullyStartd |
| Event when the path mover reach target speed. | |
| SimulationPathEvent | OnBlocked |
| Event when the path mover is blocked. | |
| SimulationStationEvent | OnStationEntered |
| Event when the path mover enter a station. | |
| SimulationStationEvent | OnStationWorkStarting |
| Event when the path mover start working within a station. | |
| SimulationStationEvent | OnStationWorkFinished |
| Event when the path mover finished working within a station. | |
| SimulationStationEvent | OnStationExit |
| Event when the path mover leave a station. | |
| MU | Mu |
| Loaded MU. | |
| float | EnteringStationDistance |
| Distance between pre- and main stopper of the current station. | |
| override void | OnStopSim () |
This component transforms MUs into smart transport entities that navigate through SimulationPath networks, automatically following routes, responding to station commands, and making decisions at path junctions. Features collision detection for traffic management, configurable alignment behavior for realistic movement, and comprehensive event system for integration with production control systems and MES interfaces. Essential for implementing AGV systems, overhead transport, pallet conveyor networks, and flexible routing in modern smart factory and Industry 4.0 applications.
◆ OnSourceCreated()
| void realvirtual.PathMover.OnSourceCreated | ( | ) |
Implements realvirtual.ISourceCreated.
◆ OnStartSim()
protectedvirtual |
◆ OnStopSim()
protectedvirtual |
◆ SelectNextPath()
| void realvirtual.PathMover.SelectNextPath | ( | PathMover | pathMover, |
| ref List< SimulationPath > | Pathes | ||
Implements realvirtual.ISelectNextPath.
◆ AlignVector
| Vector3 realvirtual.PathMover.AlignVector |
◆ AlignWithPath
| bool realvirtual.PathMover.AlignWithPath |
◆ CurrentStation
| BaseStation realvirtual.PathMover.CurrentStation |
◆ CurrentStationWorking
| BaseStation realvirtual.PathMover.CurrentStationWorking |
◆ EnteringStationDistance
| float realvirtual.PathMover.EnteringStationDistance |
◆ IsBlocked
| bool realvirtual.PathMover.IsBlocked |
◆ IsOnPathEnd
| bool realvirtual.PathMover.IsOnPathEnd |
◆ IsStarting
| bool realvirtual.PathMover.IsStarting |
◆ IsStopped
| bool realvirtual.PathMover.IsStopped |
◆ IsStopping
| bool realvirtual.PathMover.IsStopping |
◆ Mu
| MU realvirtual.PathMover.Mu |
Loaded MU.
◆ OnBlocked
| SimulationPathEvent realvirtual.PathMover.OnBlocked |
◆ OnFullyStartd
| SimulationPathEvent realvirtual.PathMover.OnFullyStartd |
◆ OnPathEnd
| SimulationPathEvent realvirtual.PathMover.OnPathEnd |
◆ OnPathEntered
| SimulationPathEvent realvirtual.PathMover.OnPathEntered |
Event when the path mover enter a path
◆ OnPathExit
| SimulationPathEvent realvirtual.PathMover.OnPathExit |
◆ OnStart
| SimulationPathEvent realvirtual.PathMover.OnStart |
◆ OnStationEntered
| SimulationStationEvent realvirtual.PathMover.OnStationEntered |
◆ OnStationExit
| SimulationStationEvent realvirtual.PathMover.OnStationExit |
◆ OnStationWorkFinished
| SimulationStationEvent realvirtual.PathMover.OnStationWorkFinished |
◆ OnStationWorkStarting
| SimulationStationEvent realvirtual.PathMover.OnStationWorkStarting |
◆ OnStopped
| SimulationPathEvent realvirtual.PathMover.OnStopped |
◆ OnStopping
| SimulationPathEvent realvirtual.PathMover.OnStopping |
◆ Path
| SimulationPath realvirtual.PathMover.Path |
◆ Position
| float realvirtual.PathMover.Position |
