realvirtual.HMI_Slider Class Reference
class to define a HMI slider More...
Inheritance diagram for realvirtual.HMI_Slider:
| new void | Awake () |
| override void | Init () |
| override void | CloseExtendedArea (Vector3 pos) |
| void | CloseSlider () |
| void | OnPointerEnter (PointerEventData eventData) |
| void | OnPointerClick (PointerEventData eventData) |
| void | OnPointerExit (PointerEventData eventData) |
Public Member Functions inherited from realvirtual.HMI | |
| TextMeshProUGUI | GetText (string objName) |
| Image | GetImage (string objName) |
| void | OnValueChanged () |
| Canvas | GetCanvas (GameObject HMIelement, ref RectTransform rectTransform) |
| void | OnTransformParentChanged () |
| void | UpdateUISkinParameter (RealvirtualUISkin skin) |
| float | MinValue |
| minimum value of the slider | |
| float | MaxValue |
| maximum value of the slider | |
| float | Value |
| current value of the slider | |
| int | FontSizeValue |
| font size of the value text | |
| bool | ActivateOnMouseEnter |
| if true, the slider is activated when the mouse enters the slider area | |
| string | Format |
| format for the float value. Default is F1 | |
| bool | UseInteger |
| if true, the slider is an integer slider | |
| string | Title |
| title of the slider | |
| int | FontSizeTitle |
| font size of the title text | |
| bool | DisplayUnit |
| if true, the unit is displayed | |
| string | Unit |
| unit of the slider | |
| int | FontSizeUnit |
| font size of the unit text | |
| Color | FontColor |
| color of the slider | |
| PLCInputInt | SignalInt |
| PLC input for the integer value. | |
| PLCInputFloat | SignalFloat |
| PLC input for the float value. | |
| PLCOutputInt | SignalIntStart |
| PLC output for the start int value of the slider. | |
| PLCOutputFloat | SignalFloatStart |
| PLC output for the start float value of the slider. | |
Public Attributes inherited from realvirtual.HMI | |
| Color | Color |
| Color of the HMI element. | |
| Color | ColorMouseOver |
| Color of the HMI element when the mouse is over it. | |
| RealVirtualHMIEvent | EventOnValueChanged |
| Event that is triggered when the value of the HMI element changes. | |
| Image | bgImg |
◆ CloseExtendedArea()
virtual |
Reimplemented from realvirtual.HMI.
◆ Init()
virtual |
◆ ActivateOnMouseEnter
| bool realvirtual.HMI_Slider.ActivateOnMouseEnter |
◆ DisplayUnit
| bool realvirtual.HMI_Slider.DisplayUnit |
◆ FontColor
| Color realvirtual.HMI_Slider.FontColor |
color of the slider
◆ FontSizeTitle
| int realvirtual.HMI_Slider.FontSizeTitle |
◆ FontSizeUnit
| int realvirtual.HMI_Slider.FontSizeUnit |
◆ FontSizeValue
| int realvirtual.HMI_Slider.FontSizeValue |
◆ Format
| string realvirtual.HMI_Slider.Format |
◆ MaxValue
| float realvirtual.HMI_Slider.MaxValue |
◆ MinValue
| float realvirtual.HMI_Slider.MinValue |
◆ SignalFloat
| PLCInputFloat realvirtual.HMI_Slider.SignalFloat |
◆ SignalFloatStart
| PLCOutputFloat realvirtual.HMI_Slider.SignalFloatStart |
◆ SignalInt
| PLCInputInt realvirtual.HMI_Slider.SignalInt |
◆ SignalIntStart
| PLCOutputInt realvirtual.HMI_Slider.SignalIntStart |
◆ Title
| string realvirtual.HMI_Slider.Title |
title of the slider
◆ Unit
| string realvirtual.HMI_Slider.Unit |
unit of the slider
◆ UseInteger
| bool realvirtual.HMI_Slider.UseInteger |
◆ Value
| float realvirtual.HMI_Slider.Value |
