Curve implements curved path segments for smooth material flow transitions in automated transport systems. More...
| override float | GetLength () |
| override Vector3 | GetDirection (float normalizedposition) |
| override Vector3 | GetPosition (float normalizedposition, ref BasePath currentpath) |
| Vector3 | RotatePointAroundPivot (Vector3 point, Vector3 pivot, Vector3 angle) |
| Vector3 | GetPathAnglePos (float angle) |
| override void | DrawPath () |
| float | AngleSigned (Vector3 v1, Vector3 v2, Vector3 n) |
| override void | AttachTo (SimulationPath path) |
| void | Reset () |
| void | setStart () |
| void | Rotate () |
| void | AttachLine () |
| void | AttachCurve () |
Public Member Functions inherited from realvirtual.SimulationPath | |
| void | OnMyStartSnapped (SimulationPath path) |
| void | OnMyStartUnsnapped (SimulationPath path) |
| void | OnMyEndSnapped (SimulationPath path) |
| void | OnMyEndUnsnapped (SimulationPath path) |
| void | TransportableEntered (PathMover trans) |
| void | TransportableOnEnd (PathMover trans) |
| void | TransportableExit (PathMover trans) |
| void | CheckSnapping () |
| void | ClearConnections () |
| void | AttachPathLine (string path, GameObject attachto) |
| void | AttachPathCurve (string path, GameObject attachto) |
| void | CheckSnap () |
| void | Connect (SnapPoint ownSnapPoint, SnapPoint snapPointMate, ISnapable mateObject, bool ismoved) |
| void | Disconnect (SnapPoint snapPoint, SnapPoint snapPointMate, ISnapable Mateobj, bool ismoved) |
| void | Modify () |
| void | AttachTo (SnapPoint attachto) |
Public Member Functions inherited from realvirtual.BasePath | |
| Gets the length of the path. | |
| Gets the position in World coordinates of the path at the defined normalized position. | |
| Gets the tangent of the pat at the defined normalized position. | |
| Vector3 | GetLocalDirection (float normalizedposition) |
| Gets the direction tangent in local coordinate system. | |
| Vector3 | GetAbsPosition (float abspositon, ref BasePath currentpath) |
| Gets the position in global coordinate system at absolute position (in meters) at the path. | |
| Vector3 | GetAbsDirection (float abspositon) |
| Gets the direction tangent in global coordinate system at absolute position (in meters) at the path. | |
| bool | Clockwise |
| float | Radius |
| Radius of the curve. | |
| float | StartAngle |
| Start angle of the curve. | |
| float | Degrees |
| Angle covered by the curve. | |
| bool | DirectionArrow |
| Boolean which activate/ deactivate the direction arrow in the middle of the line. | |
| GameObject | CenterDebug |
| GameObject | PosDebug |
| GameObject | TanDebug |
Public Attributes inherited from realvirtual.SimulationPath | |
| Drive | Drive |
| drive used on the simulation path | |
| bool | DriveNotNull |
| PathStrategy | PathStrategy |
| Path strategy which defines the behavior at certain path events. | |
| List< SimulationPath > | Predecessors |
| List of predecessors, is filled automatically. | |
| List< SimulationPath > | Successors |
| List of successors, is filled automatically. | |
| SimulationPathEvent | OnPathEntered |
| List with methods called when a path mover enter the path. | |
| SimulationPathEvent | OnPathEnd |
| List with methods called when a path mover reach the end of a path. | |
| SimulationPathEvent | OnPathExit |
| List with methods called when a path mover exit the path. | |
| float | Length |
| Length of the path. | |
| bool | ShowPathOnSimulation |
| Boolean specifying whether the path is visible during runtime or not. | |
| float | Thickness |
| Thickness of the simulation path. | |
| Material | MaterialPath |
| Material of the simulation path. | |
| float | SizeDirectionArrow |
| Size of the direction arrow in the center of the path. | |
| GameObject | StartPoint |
| GameObject | EndPoint |
| bool | EnableSnap |
| bool | movedlocally |
| bool | transformposchanged |
Protected Member Functions inherited from realvirtual.SimulationPath | |
| virtual void | LengthChanged () |
| void | SetStartTo0 () |
| void | DrawArrows () |
| void | BaseReset () |
Protected Attributes inherited from realvirtual.SimulationPath | |
| LineRenderer | Linerenderer |
| bool | blockdraw |
| Arrow | _startarrow |
| Arrow | _endarrow |
Properties inherited from realvirtual.SimulationPath | |
| Vector3 | LocalStartPos [get, set] |
| Vector3 | LocalEndPos [get, set] |
| Vector3 | StartPos [get, set] |
| Vector3 | EndPos [get, set] |
| OnSnappedEvent | OnSnapped [get, set] |
Properties inherited from realvirtual.ISnapable | |
This component creates arc-shaped path sections with configurable radius and angle, enabling realistic cornering behavior for AGVs, conveyor transfers, and material handling equipment. Supports both clockwise and counter-clockwise curves with precise angular control, automatic endpoint snapping for seamless network integration, and smooth interpolation for natural movement patterns. Critical for designing efficient factory layouts with space-optimized routing, turntables, and curved conveyor sections in modern intralogistics and flexible manufacturing systems.
◆ AttachTo()
virtual |
Reimplemented from realvirtual.SimulationPath.
◆ DrawPath()
virtual |
◆ Degrees
| float realvirtual.Curve.Degrees |
◆ DirectionArrow
| bool realvirtual.Curve.DirectionArrow |
◆ Radius
| float realvirtual.Curve.Radius |
◆ StartAngle
| float realvirtual.Curve.StartAngle |
