Public Member Functions |
Static Public Member Functions |
Public Attributes |
Protected Member Functions |
List of all members
realvirtual.UniversalRobotsInterface Class Reference
Inheritance diagram for realvirtual.UniversalRobotsInterface:
| void | DeleteSignals () |
| static byte | SetBit (byte b, int BitNumber) |
| string | UrIpAdress |
| URSIM IP Adress. | |
| int | OutputFrequency |
| Frequency per second in which the outputs of URSIM are read. | |
| List< Drive > | Axis |
| The axis of the robot. | |
| List< PLCOutputBool > | DigitalOutputs |
| The Digital outputs of the robot, PLCOutputBool. | |
| List< PLCOutputBool > | ConfigurableOutputs |
| The configurable outputs of the robot, PLCOutputBool. | |
| List< PLCInputBool > | DigitalInputs |
| The inputs of the robot, PLCInputBool. | |
| List< PLCInputBool > | ConfigurableInputs |
| The configurable inputs of the robot, PLCInputtBool. | |
| UInt64 | RobotDigitalInputs |
| UInt64 | RobotDigitalOutputs |
| UInt32 | RobotStatusBits |
| UInt32 | RobotProgramState |
Public Attributes inherited from realvirtual.InterfaceThreadedBaseClass | |
| int | MinUpdateCycle |
| int | CommCycleMeasures |
| int | CommCycleNr |
| int | CommTimeMs |
| int | CommTimeMin |
| float | CommTimeMed |
| int | CommTimeMax |
| int | CommCycleMeasureNum |
| int | UpdateCycleMs |
| string | ThreadStatus |
| int | MinUpdateCycle2 |
| int | CommCycleNr2 |
| int | CommTimeMs2 |
| int | CommTimeMin2 |
| float | CommTimeMed2 |
| int | CommTimeMax2 |
| int | CommCycleMeasureNum2 |
| int | UpdateCycleMs2 |
| string | ThreadStatus2 |
| bool | NoThreading |
| bool | TwoThreads |
| bool | IsConnected |
| override void | CommunicationThreadUpdate () |
Protected Member Functions inherited from realvirtual.InterfaceThreadedBaseClass | |
| virtual void | CommunicationThreadClose () |
| virtual void | SecondCommunicationThreadUpdate () |
| virtual void | SecondCommunicationThreadClose () |
| void | OnConnected () |
| void | OnDisconnected () |
| void | OnEnable () |
| void | OnDisable () |
◆ CloseInterface()
virtual |
Reimplemented from realvirtual.InterfaceThreadedBaseClass.
◆ CommunicationThreadUpdate()
protectedvirtual |
◆ OpenInterface()
virtual |
◆ Axis
| List<Drive> realvirtual.UniversalRobotsInterface.Axis |
◆ ConfigurableInputs
| List<PLCInputBool> realvirtual.UniversalRobotsInterface.ConfigurableInputs |
◆ ConfigurableOutputs
| List<PLCOutputBool> realvirtual.UniversalRobotsInterface.ConfigurableOutputs |
◆ DigitalInputs
| List<PLCInputBool> realvirtual.UniversalRobotsInterface.DigitalInputs |
◆ DigitalOutputs
| List<PLCOutputBool> realvirtual.UniversalRobotsInterface.DigitalOutputs |
◆ OutputFrequency
| int realvirtual.UniversalRobotsInterface.OutputFrequency |
◆ UrIpAdress
| string realvirtual.UniversalRobotsInterface.UrIpAdress |
URSIM IP Adress.
