| Axis | realvirtual.UniversalRobotsInterface | |
| CloseInterface() (defined in realvirtual.UniversalRobotsInterface) | realvirtual.UniversalRobotsInterface | virtual |
| CommCycleMeasureNum (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleMeasureNum2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleMeasures (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleNr (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleNr2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMax (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMax2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMed (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMed2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMin (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMin2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMs (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMs2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommunicationThreadClose() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| CommunicationThreadUpdate() (defined in realvirtual.UniversalRobotsInterface) | realvirtual.UniversalRobotsInterface | protectedvirtual |
| ConfigurableInputs | realvirtual.UniversalRobotsInterface | |
| ConfigurableOutputs | realvirtual.UniversalRobotsInterface | |
| DigitalInputs | realvirtual.UniversalRobotsInterface | |
| DigitalOutputs | realvirtual.UniversalRobotsInterface | |
| MinUpdateCycle (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| MinUpdateCycle2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| NoThreading (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| OpenInterface() (defined in realvirtual.UniversalRobotsInterface) | realvirtual.UniversalRobotsInterface | virtual |
| OutputFrequency | realvirtual.UniversalRobotsInterface | |
| RobotDigitalInputs (defined in realvirtual.UniversalRobotsInterface) | realvirtual.UniversalRobotsInterface | |
| RobotDigitalOutputs (defined in realvirtual.UniversalRobotsInterface) | realvirtual.UniversalRobotsInterface | |
| RobotProgramState (defined in realvirtual.UniversalRobotsInterface) | realvirtual.UniversalRobotsInterface | |
| RobotStatusBits (defined in realvirtual.UniversalRobotsInterface) | realvirtual.UniversalRobotsInterface | |
| SecondCommunicationThreadClose() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| SecondCommunicationThreadUpdate() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| SetBit(byte b, int BitNumber) (defined in realvirtual.UniversalRobotsInterface) | realvirtual.UniversalRobotsInterface | static |
| ThreadStatus (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| ThreadStatus2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| TwoThreads (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| UpdateCycleMs (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| UpdateCycleMs2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| UrIpAdress | realvirtual.UniversalRobotsInterface | |
