Defines precise robot target positions with industrial motion parameters for accurate path execution. More...
Public Types | |
| enum | Interploation { PointToPoint , PointToPointUnsynced , Linear } |
| void | OnAtTarget () |
| Vector3 | GetCorrectedGlobalPosition () |
| void | OnLeaveTarget () |
| void | SetAsTarget () |
| void | DriveTo () |
| bool | FollowInEditMode |
| If true the target will follow the robot in edit mode. | |
| Vector3 | PosRH |
| Position of the target in right handed robot coordinates. | |
| Vector3 | RotRH |
| Rotation of the target in right handed robot coordinates. | |
| float | SpeedToTarget |
| Speed to target in percent. | |
| float | LinearAcceleration |
| Linear acceleration in mm/s^2. | |
| Interploation | InterpolationToTarget |
| Interpolation to target. | |
| float | LinearSpeedToTarget |
| Linear speed to target in mm/s. | |
| bool | TurnCorrection |
| If true the robot will do the 180 degree turn correction of axis 4 and 6. | |
| float[] | AxisCorrection |
| Correction of the axis in degrees. | |
| PLCInputBool | SetSignal |
| Set Signal if target is reached. | |
| float | SetSignalDuration |
| Duration of the set signal in seconds. | |
| float | WaitForSeconds |
| Wait for seconds after target is reached. | |
| PLCOutputBool | WaitForSignal |
| bool | PickAndPlace |
| Wait for signal after target is reached. | |
| Fixer | fixer |
| Fixer component for pick and place operations (legacy) | |
| Grip | gripTarget |
| Grip component for simplified pick and place (alternative to fixer) | |
| bool | Pick |
| bool | Place |
| bool | EnableBlending |
| Enables zone blending - robot transitions to next target at BlendRadius distance instead of stopping exactly at this target. | |
| float | BlendRadius |
| Blend radius in millimeters - robot starts moving toward next target when within this distance of the current target. | |
| int | Solution |
| Raw IK solution index (0-7 for Pieper seeds) identifying the physical robot configuration. | |
| string[] | Solutions |
| Sorted reachable solutions of the IK for this target (index 0 = closest to reference angles) | |
| int[] | SolutionRawIndices |
| Maps sorted display position to raw IK solution index (SolutionRawIndices[displayPos] = rawIndex) | |
| int | ReachableSolutionCount |
| Number of reachable IK solutions found. | |
| float[] | AxisPos |
| Axis positions of the IK for this target. | |
| float[] | ReferenceAngles |
| Reference joint angles used for sorting solutions (from previous path target or current robot position) | |
| RobotIK | RobotIK |
| Robot IK of the robot. | |
| bool | Reachable |
| If true the target is reachable by the robot. | |
This professional component represents waypoints in robotic paths with configurable interpolation modes, speed parameters, and signal coordination. Supports linear and point-to-point motion, axis corrections, and integration with pick-and-place operations for comprehensive robotic programming in automation systems.
◆ AxisCorrection
| float [] realvirtual.IKTarget.AxisCorrection |
◆ AxisPos
| float [] realvirtual.IKTarget.AxisPos |
◆ BlendRadius
| float realvirtual.IKTarget.BlendRadius |
◆ EnableBlending
| bool realvirtual.IKTarget.EnableBlending |
◆ fixer
| Fixer realvirtual.IKTarget.fixer |
◆ FollowInEditMode
| bool realvirtual.IKTarget.FollowInEditMode |
◆ gripTarget
| Grip realvirtual.IKTarget.gripTarget |
◆ InterpolationToTarget
| Interploation realvirtual.IKTarget.InterpolationToTarget |
◆ LinearAcceleration
| float realvirtual.IKTarget.LinearAcceleration |
◆ LinearSpeedToTarget
| float realvirtual.IKTarget.LinearSpeedToTarget |
◆ PickAndPlace
| bool realvirtual.IKTarget.PickAndPlace |
◆ PosRH
| Vector3 realvirtual.IKTarget.PosRH |
◆ Reachable
| bool realvirtual.IKTarget.Reachable |
◆ ReachableSolutionCount
| int realvirtual.IKTarget.ReachableSolutionCount |
◆ ReferenceAngles
| float [] realvirtual.IKTarget.ReferenceAngles |
◆ RobotIK
| RobotIK realvirtual.IKTarget.RobotIK |
◆ RotRH
| Vector3 realvirtual.IKTarget.RotRH |
◆ SetSignal
| PLCInputBool realvirtual.IKTarget.SetSignal |
◆ SetSignalDuration
| float realvirtual.IKTarget.SetSignalDuration |
◆ Solution
| int realvirtual.IKTarget.Solution |
◆ SolutionRawIndices
| int [] realvirtual.IKTarget.SolutionRawIndices |
◆ Solutions
| string [] realvirtual.IKTarget.Solutions |
◆ SpeedToTarget
| float realvirtual.IKTarget.SpeedToTarget |
◆ TurnCorrection
| bool realvirtual.IKTarget.TurnCorrection |
◆ WaitForSeconds
| float realvirtual.IKTarget.WaitForSeconds |
Public Types inherited from
