Provides industrial robot inverse kinematics for 6-axis robotic arms with advanced path planning and motion control. More...
| Vector3 | GetTCPPosGlobal () |
| Quaternion | GetTCPRotGlobal () |
| void | SetExternalControl (bool enabled) |
| Enable or disable external control mode for all robot axes. | |
| void | TargetMoveEditMode (bool active) |
| void | MoveEditMode () |
| void | ToHomePos () |
| void | SetTCP (GameObject tcp) |
| void | SetTargetProperties (IKTarget target) |
| void | SolveIK (IKTarget target) |
| bool | PositionRobotGlobal (Vector3 globalpos, Quaternion globalrot, int sortedSolutionIndex, bool TurnCorrection) |
| JobHandle | SchedulePositionRobotGlobal (Vector3 globalpos, Quaternion globalrot, int solution, bool turnCorrection) |
| Schedule IK calculation asynchronously. | |
| bool | CompletePositionRobotGlobal () |
| Complete the scheduled IK job and position drives. | |
| void | SetReferenceAngles (float[] referenceAngles) |
| Sets the reference angles used for sorting IK solutions. | |
| void | SetReferenceAnglesToCurrentPosition () |
| Sets the reference angles from the current robot joint positions. | |
| void | SolveIKWithReference (IKTarget target, float[] referenceAngles) |
| Solves IK for the target and uses referenceAngles to sort reachable solutions. | |
| int | Solution |
| The current raw IK solution index used for positioning drives. | |
| string[] | Solutions |
| The sorted reachable solutions of the IK calculation (index 0 = closest to reference angles) | |
| int[] | SolutionRawIndices |
| Maps sorted display position to raw IK solution index. | |
| bool | MoveInEditMode |
| Move the robot in edit mode. | |
| bool | FollowTarget |
| Follow the target in edit mode. | |
| IKTarget | Target |
| The target to follow in edit mode. | |
| Vector3 | TargetPosRightHanded |
| The target position in right handed coordinates. | |
| Vector3 | TargetRotRightHanded |
| The target rotation in right handed coordinates. | |
| bool | DrawGizmos |
| Draw TCP marker, axis directions and limit arcs in scene view. | |
| bool | ShowElbowDirection |
| Show elbow direction arrow at robot base. | |
| bool | ShowKinematicChain |
| Show DH kinematic chain with segment lengths. | |
| bool | ShowJointPositions |
| Show current joint positions as needles within limit arcs. | |
| bool | ShowAxisFrames |
| Show local coordinate frames and rotation direction at each axis. | |
| bool | ShowWristType |
| Show wrist type indicator (sphere for spherical, offsets for non-spherical) | |
| bool | ElbowInUnityX |
| The elbow is in the Unity X direction. | |
| Drive[] | Axis |
| The drives of the robot. | |
| GameObject | TCP |
| The TCP of the robot. | |
| IKTarget | HomePosOnStart |
| The home position of the robot on start. | |
| RobotWristType | WristType |
| Wrist kinematic type: Spherical for standard robots, NonSpherical (BETA) for cobots with wrist offsets. | |
| SolutionSelectionMode | SolutionSelection |
| Strategy for selecting among valid IK solutions when the requested one is unreachable. | |
| bool | MirrorSeeds |
| Generate 8 mirrored wrist-flip seeds from the 4 Pieper base configurations to find additional solutions. | |
| int | HaltonSeedCount |
| Number of Halton low-discrepancy fallback seeds (0 = disabled); adds random joint-space seeds for hard-to-reach poses. | |
| float | NRAngularWeight |
| Weight for orientation vs position in NR solver. | |
| float | NROrientationTolerance |
| Orientation convergence tolerance in radians (0.57 degrees) | |
| bool | NRDiagnostics |
| Enable NR convergence logging to Unity console. | |
| double | d4 |
| Wrist offset from axis 3 to axis 4 in millimeters (auto-calculated) | |
| double | d5 |
| Wrist offset from axis 4 to axis 5 in millimeters (auto-calculated) | |
| double | a5 |
| Wrist length parameter of axis 5 in millimeters (auto-calculated) | |
| double | a6 |
| Wrist length parameter of axis 6 in millimeters (auto-calculated) | |
| Vector3 | ToolOffset |
| The tool offset of the TCP. | |
| double | a1 |
| The a1 parameter of the robot. | |
| double | a2 |
| double | b |
| double | c1 |
| double | c2 |
| double | c3 |
| double | c4 |
| The a2, b, c1, c2, c3, c4 parameter of the robot. | |
Properties | |
| bool | IsNonSphericalWrist [get] |
| Returns true when WristType is NonSpherical. Used by NaughtyAttributes [ShowIf] to conditionally display solver parameters. | |
| bool | HasScheduledJob [get] |
| Check if an IK job is currently scheduled. | |
This professional component enables precise robot control through inverse kinematics calculations, supporting multiple IK solutions, TCP management, and seamless integration with drive systems. Used for virtual commissioning of robotic cells, path validation, and cycle time optimization in industrial automation scenarios.
◆ CompletePositionRobotGlobal()
| bool realvirtual.RobotIK.CompletePositionRobotGlobal | ( | ) |
Returns true if position is reachable.
◆ SchedulePositionRobotGlobal()
| JobHandle realvirtual.RobotIK.SchedulePositionRobotGlobal | ( | Vector3 | globalpos, |
| Quaternion | globalrot, | ||
| int | solution, | ||
| bool | turnCorrection | ||
Call CompletePositionRobotGlobal() to get results. This allows other work to run while IK calculates on a worker thread. Returns the JobHandle for combining with other IK jobs for parallel execution.
◆ SetExternalControl()
| void realvirtual.RobotIK.SetExternalControl | ( | bool | enabled | ) |
When enabled, axes skip their normal FixedUpdate calculations (IK sets position directly). Call with true when IKPath starts, false when it ends.
◆ SetReferenceAngles()
| void realvirtual.RobotIK.SetReferenceAngles | ( | float[] | referenceAngles | ) |
Call before SolveIK() to enable MinimalAngleChange-based solution sorting. Angles are in degrees.
◆ SetReferenceAnglesToCurrentPosition()
| void realvirtual.RobotIK.SetReferenceAnglesToCurrentPosition | ( | ) |
Used as fallback when no previous path target exists.
◆ SetTargetProperties()
| void realvirtual.RobotIK.SetTargetProperties | ( | IKTarget | target | ) |
Don't display / update on playing because of NaughtyAttributes bug
◆ SolveIKWithReference()
| void realvirtual.RobotIK.SolveIKWithReference | ( | IKTarget | target, |
| float[] | referenceAngles | ||
If referenceAngles is null, uses current robot joint positions as reference.
◆ a1
| double realvirtual.RobotIK.a1 |
◆ a5
| double realvirtual.RobotIK.a5 |
◆ a6
| double realvirtual.RobotIK.a6 |
◆ Axis
| Drive [] realvirtual.RobotIK.Axis |
◆ c4
| double realvirtual.RobotIK.c4 |
◆ d4
| double realvirtual.RobotIK.d4 |
◆ d5
| double realvirtual.RobotIK.d5 |
◆ DrawGizmos
| bool realvirtual.RobotIK.DrawGizmos |
◆ ElbowInUnityX
| bool realvirtual.RobotIK.ElbowInUnityX |
◆ FollowTarget
| bool realvirtual.RobotIK.FollowTarget |
◆ HaltonSeedCount
| int realvirtual.RobotIK.HaltonSeedCount |
◆ HomePosOnStart
| IKTarget realvirtual.RobotIK.HomePosOnStart |
◆ MirrorSeeds
| bool realvirtual.RobotIK.MirrorSeeds |
◆ MoveInEditMode
| bool realvirtual.RobotIK.MoveInEditMode |
◆ NRAngularWeight
| float realvirtual.RobotIK.NRAngularWeight |
◆ NRDiagnostics
| bool realvirtual.RobotIK.NRDiagnostics |
◆ NROrientationTolerance
| float realvirtual.RobotIK.NROrientationTolerance |
◆ ShowAxisFrames
| bool realvirtual.RobotIK.ShowAxisFrames |
◆ ShowElbowDirection
| bool realvirtual.RobotIK.ShowElbowDirection |
◆ ShowJointPositions
| bool realvirtual.RobotIK.ShowJointPositions |
◆ ShowKinematicChain
| bool realvirtual.RobotIK.ShowKinematicChain |
◆ ShowWristType
| bool realvirtual.RobotIK.ShowWristType |
◆ Solution
| int realvirtual.RobotIK.Solution |
◆ SolutionRawIndices
| int [] realvirtual.RobotIK.SolutionRawIndices |
◆ Solutions
| string [] realvirtual.RobotIK.Solutions |
◆ SolutionSelection
| SolutionSelectionMode realvirtual.RobotIK.SolutionSelection |
◆ Target
| IKTarget realvirtual.RobotIK.Target |
◆ TargetPosRightHanded
| Vector3 realvirtual.RobotIK.TargetPosRightHanded |
◆ TargetRotRightHanded
| Vector3 realvirtual.RobotIK.TargetRotRightHanded |
◆ TCP
| GameObject realvirtual.RobotIK.TCP |
◆ ToolOffset
| Vector3 realvirtual.RobotIK.ToolOffset |
◆ WristType
| RobotWristType realvirtual.RobotIK.WristType |
Property Documentation
◆ HasScheduledJob
get |
◆ IsNonSphericalWrist
get |
