Fixer component for securing MUs to specific positions or surfaces in the automation system. More...
| void | OnMultiplayer (bool isclient, bool isstart) |
| stops Fixer on Multiplayer Client | |
| void | Pick () |
| public for Fix all currently colliding MUs | |
| void | Place () |
| void | OnTriggerEnter (Collider other) |
| void | OnTriggerExit (Collider other) |
| void | CheckRelease () |
| void | Unfix (MU mu) |
| void | DeActivate (bool activate) |
| void | Fix (MU mu) |
| bool | UseRayCast |
| Use Raycasts instead of Box Collider for detecting parts. | |
| List< string > | LimitToTags |
| Limits all Fixing functions to objects with defined Tags. | |
| Vector3 | RaycastDirection |
| Raycast direction. | |
| float | RayCastLength |
| Length of Raycast in mm. | |
| List< string > | RayCastLayers |
| Raycast Layers. | |
| bool | FixMU |
| bool | DeactivatePhysicsWhenPlacing |
| bool | AlignAndFixOnMinDistance |
| true if MU should be fixed or aligned when Distance between MU and Fixer is minimum (distance is increasing again) | |
| bool | AlignMU |
| true if pivot Points of MU and Fixer should be aligned | |
| Vector3 | DeltaAlign |
| string | SetTagAfterFix |
| Vector3 | DeltaRot |
| bool | ShowStatus |
| float | StatusOpacity |
| true if Status of Collider or Raycast should be displayed | |
| bool | BlockHandingOver |
| Opacity of Mesh in case of status display. | |
| bool | OneBitFix |
| if true the fixer will not be able to hand over the MU to another fixer which is colliding with the MU | |
| PLCOutputBool | FixerFix |
| Only controlled by Signal FixerFix - with one bit. | |
| PLCOutputBool | FixerRelease |
| PLCOutputBool | SignalBlockHandingOver |
| PLCSignal for releasing current MUs and turning Fixer off. | |
| bool | DebugMode |
| List< MU > | MUSEntered |
| List< MU > | MUSFixed |
The Fixer component is an essential tool for position management in realvirtual simulations, providing mechanisms to secure MUs at specific locations within the production system. It enables precise control over material positioning, whether for temporary holding, permanent placement, or transfer operations. The component operates through collision detection or raycast sensing, automatically fixing MUs when they enter the detection zone and managing their physics state for stable positioning.
Key Features:
- Dual detection modes: BoxCollider-based or Raycast-based sensing
- Automatic fixing on contact with configurable release conditions
- Alignment capabilities for precise MU positioning with offset control
- Tag-based filtering to restrict fixing to specific MU types
- Minimum distance detection for optimal fixing timing
- Handover blocking to prevent unwanted transfers between fixers
- Visual status indication for debugging and monitoring
- Physics deactivation option for performance optimization
Common Applications:
- Workstation positioning and material holding
- Conveyor stop gates and accumulation zones
- Pallet positioning on transfer stations
- Buffer storage locations in production lines
- Quality inspection stations requiring stable MU positioning
- Assembly fixtures and jigs
- Loading/unloading positions for AGVs and robots
Operation Modes: The Fixer supports multiple operation modes to accommodate different automation scenarios. In automatic mode (FixMU=true), MUs are fixed immediately upon detection. In signal-controlled mode, fixing and releasing are controlled through PLC signals, supporting both single-bit (toggle) and dual-bit (separate fix/release) control schemes. The AlignAndFixOnMinDistance mode enables intelligent fixing when the MU reaches its closest approach, ideal for moving conveyors and transfer operations.
Integration Points: The Fixer integrates with the MU system for material tracking, supports handover protocols between multiple fixers, and can be controlled through PLC signals (PLCOutputBool) for industrial control system integration. It works seamlessly with conveyors, robots, and other transport systems, managing the transition between moving and stationary states.
Performance Considerations: The component efficiently manages fixed MUs through list-based tracking and provides options for physics optimization. When DeactivatePhysicsWhenPlacing is enabled, released MUs have their physics disabled, reducing computational overhead in scenarios where movement is not required. The raycast mode offers precise detection with lower performance impact compared to collision-based detection for simple geometries.
Visual Feedback: When ShowStatus is enabled, the Fixer provides visual feedback through color-coded indicators (red for empty, green for occupied) and raycast visualization, facilitating debugging and system monitoring during development and commissioning phases.
For detailed documentation and examples, visit: https://doc.realvirtual.io/components-and-scripts/fixer
◆ DeActivate()
| void realvirtual.Fixer.DeActivate | ( | bool | activate | ) |
Implements realvirtual.IFix.
◆ Fix()
| void realvirtual.Fixer.Fix | ( | MU | mu | ) |
◆ OnMultiplayer()
| void realvirtual.Fixer.OnMultiplayer | ( | bool | isclient, |
| bool | isstart | ||
Implements realvirtual.IMultiPlayer.
◆ Pick()
| void realvirtual.Fixer.Pick | ( | ) |
◆ Place()
| void realvirtual.Fixer.Place | ( | ) |
◆ Unfix()
| void realvirtual.Fixer.Unfix | ( | MU | mu | ) |
◆ AlignAndFixOnMinDistance
| bool realvirtual.Fixer.AlignAndFixOnMinDistance |
◆ AlignMU
| bool realvirtual.Fixer.AlignMU |
◆ BlockHandingOver
| bool realvirtual.Fixer.BlockHandingOver |
◆ FixerFix
| PLCOutputBool realvirtual.Fixer.FixerFix |
◆ LimitToTags
| List<string> realvirtual.Fixer.LimitToTags |
◆ OneBitFix
| bool realvirtual.Fixer.OneBitFix |
◆ RaycastDirection
| Vector3 realvirtual.Fixer.RaycastDirection |
Raycast direction.
◆ RayCastLayers
| List<string> realvirtual.Fixer.RayCastLayers |
Raycast Layers.
◆ RayCastLength
| float realvirtual.Fixer.RayCastLength |
◆ SignalBlockHandingOver
| PLCOutputBool realvirtual.Fixer.SignalBlockHandingOver |
◆ StatusOpacity
| float realvirtual.Fixer.StatusOpacity |
◆ UseRayCast
| bool realvirtual.Fixer.UseRayCast |
