| AlignAndFixOnMinDistance | realvirtual.Fixer | |
| AlignMU | realvirtual.Fixer | |
| BlockHandingOver | realvirtual.Fixer | |
| CheckRelease() (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| DeActivate(bool activate) (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| DeactivatePhysicsWhenPlacing (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| DebugMode (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| DeltaAlign (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| DeltaRot (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| Fix(MU mu) (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| FixerFix | realvirtual.Fixer | |
| FixerRelease (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| FixMU (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| LimitToTags | realvirtual.Fixer | |
| MUSEntered (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| MUSFixed (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| OneBitFix | realvirtual.Fixer | |
| OnMultiplayer(bool isclient, bool isstart) | realvirtual.Fixer | |
| OnTriggerEnter(Collider other) (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| OnTriggerExit(Collider other) (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| Pick() | realvirtual.Fixer | |
| Place() | realvirtual.Fixer | |
| RaycastDirection | realvirtual.Fixer | |
| RayCastLayers | realvirtual.Fixer | |
| RayCastLength | realvirtual.Fixer | |
| SetTagAfterFix (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| ShowStatus (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| SignalBlockHandingOver | realvirtual.Fixer | |
| StatusOpacity | realvirtual.Fixer | |
| Unfix(MU mu) (defined in realvirtual.Fixer) | realvirtual.Fixer | |
| UseRayCast | realvirtual.Fixer | |
