Moves Rigidbodies based on joints and forces. More...
| float | ForceNewton |
| Force in Newton. | |
| bool | DebugMode |
| float | DebugScale |
| bool | Forward |
| Apply the force in forward direction based on attached Joint direction. | |
| bool | Backward |
| Apply the force in backward direction based on attached Joint direction. | |
| PLCOutputFloat | SignalForce |
| PLC output signal for force (connection is optional) | |
| PLCOutputBool | ForceForward |
| PLC output signal for applying force in forward direction (connection is optional) | |
| PLCOutputBool | ForceBackward |
| PLC output signal for applying force in backward direction (connection is optional) | |
| PLCOutputBool | SignalBrake |
| PLC Signal for breaking. | |
| PLCInputBool | OnUpperLimit |
| PLC input signal, true if attached joint reaches upper limit. | |
| PLCInputBool | OnLowerLimit |
| PLC input signal, true if attached joint reaches lower limit. | |
| PLCInputFloat | CurrentPosition |
| PLC Signal for the current joints position. | |
Public Member Functions inherited from realvirtual.ISignalInterface | |
Acts like a cylinder, forward and backward movement can controlled by PLC signals. In comparison to Drive_Cylinder this component is fully compatible with Unity physics but the positioning to an exact position is not possible due to pure physics based behaviour
◆ Backward
| bool realvirtual.ForceDrive.Backward |
◆ CurrentPosition
| PLCInputFloat realvirtual.ForceDrive.CurrentPosition |
◆ ForceBackward
| PLCOutputBool realvirtual.ForceDrive.ForceBackward |
◆ ForceForward
| PLCOutputBool realvirtual.ForceDrive.ForceForward |
◆ ForceNewton
| float realvirtual.ForceDrive.ForceNewton |
Force in Newton.
◆ Forward
| bool realvirtual.ForceDrive.Forward |
◆ OnLowerLimit
| PLCInputBool realvirtual.ForceDrive.OnLowerLimit |
◆ OnUpperLimit
| PLCInputBool realvirtual.ForceDrive.OnUpperLimit |
◆ SignalBrake
| PLCOutputBool realvirtual.ForceDrive.SignalBrake |
◆ SignalForce
| PLCOutputFloat realvirtual.ForceDrive.SignalForce |
Public Attributes inherited from
