Drive_DestinationMotor provides position-controlled movement for Drive components. More...
| void | CalcFixedUpdate () |
| float | CurrentPositionScale |
| Scale factor for the current position feedback. | |
| float | CurrentPositionOffset |
| Offset applied to position command and feedback in millimeters. | |
| bool | ScaleFeedbackPosition |
| If true, applies scale and offset to position feedback. | |
| PLCOutputFloat | Speed |
| Current Speed of the drive in millimeters / second. | |
| PLCOutputBool | StartDrive |
| Start to drive Signal. | |
| PLCOutputFloat | Destination |
| Destination position of the drive in millimeters. | |
| PLCOutputFloat | Acceleration |
| Acceleration of the drive in millimeters / second. | |
| PLCOutputFloat | TargetSpeed |
| Target (maximum) speed of the drive in mm/ second. | |
| PLCInputFloat | IsAtPosition |
| Signal is true if Drive is at destination position. | |
| PLCInputFloat | IsAtSpeed |
| Signal for current Drive speed in mm / second. | |
| PLCInputBool | IsAtDestination |
| Signal if Drive is at Destination. | |
| PLCInputBool | IsDriving |
| Signal is true if Drive is currently driving. | |
Implements servo-like behavior with target position control, speed regulation, and acceleration management. Ideal for precise positioning applications like NC axes, robotics, and automated positioning systems.
◆ CalcFixedUpdate()
| void realvirtual.Drive_DestinationMotor.CalcFixedUpdate | ( | ) |
◆ OnStartSim()
protectedvirtual |
◆ Acceleration
| PLCOutputFloat realvirtual.Drive_DestinationMotor.Acceleration |
◆ CurrentPositionOffset
| float realvirtual.Drive_DestinationMotor.CurrentPositionOffset |
◆ CurrentPositionScale
| float realvirtual.Drive_DestinationMotor.CurrentPositionScale |
◆ Destination
| PLCOutputFloat realvirtual.Drive_DestinationMotor.Destination |
◆ IsAtDestination
| PLCInputBool realvirtual.Drive_DestinationMotor.IsAtDestination |
◆ IsAtPosition
| PLCInputFloat realvirtual.Drive_DestinationMotor.IsAtPosition |
◆ IsAtSpeed
| PLCInputFloat realvirtual.Drive_DestinationMotor.IsAtSpeed |
◆ IsDriving
| PLCInputBool realvirtual.Drive_DestinationMotor.IsDriving |
◆ ScaleFeedbackPosition
| bool realvirtual.Drive_DestinationMotor.ScaleFeedbackPosition |
◆ Speed
| PLCOutputFloat realvirtual.Drive_DestinationMotor.Speed |
◆ StartDrive
| PLCOutputBool realvirtual.Drive_DestinationMotor.StartDrive |
◆ TargetSpeed
| PLCOutputFloat realvirtual.Drive_DestinationMotor.TargetSpeed |
