realvirtual.SimulinkInterface Class Reference
Shared memory interface for an interface based on Siemens Simit shared memory structure (see Simit documentation) More...
Inheritance diagram for realvirtual.SimulinkInterface:
| void | ImportSignals (bool simstart) |
| void | UpdateSignals () |
| void | ImportSignals () |
| void | DeleteSignals () |
| string | SHMName |
| Name of the Shared memory. | |
| bool | DebugMode |
| string | Status |
| Status of the interface during simulation "SHM connected" if everythin is OK (ReadOnly) | |
| int | SimulinkStatus |
| float | SimulinkSpeed |
| int | SimulinkCycle |
| int | G4ASStatus |
| float | G4ASpeed |
| int | G4ACycle |
| List< SHMSignal > | Signals |
| The signals in the shared memory. | |
| bool | IsConnected |
Protected Member Functions inherited from realvirtual.InterfaceSHMBaseClass | |
| void | WriteString (MemoryMappedViewAccessor accessor, string text, long pos) |
| string | ReadString (MemoryMappedViewAccessor accessor, long pos, int size) |
| void | OnConnected () |
| void | OnDisconnected () |
| void | OnEnable () |
| void | OnDisable () |
◆ CloseInterface()
virtual |
Reimplemented from realvirtual.InterfaceBaseClass.
◆ ImportSignals()
| void realvirtual.SimulinkInterface.ImportSignals | ( | bool | simstart | ) |
HEADER
Create Signals Object if not existing
◆ OpenInterface()
virtual |
◆ SHMName
| string realvirtual.SimulinkInterface.SHMName |
◆ Signals
| List<SHMSignal> realvirtual.SimulinkInterface.Signals |
◆ Status
| string realvirtual.SimulinkInterface.Status |
