| CloseInterface() (defined in realvirtual.SimulinkInterface) | realvirtual.SimulinkInterface | virtual |
| DebugMode (defined in realvirtual.SimulinkInterface) | realvirtual.SimulinkInterface | |
| G4ACycle (defined in realvirtual.SimulinkInterface) | realvirtual.SimulinkInterface | |
| G4ASpeed (defined in realvirtual.SimulinkInterface) | realvirtual.SimulinkInterface | |
| G4ASStatus (defined in realvirtual.SimulinkInterface) | realvirtual.SimulinkInterface | |
| ImportSignals(bool simstart) | realvirtual.SimulinkInterface | |
| ImportSignals() (defined in realvirtual.SimulinkInterface) | realvirtual.SimulinkInterface | |
| OpenInterface() (defined in realvirtual.SimulinkInterface) | realvirtual.SimulinkInterface | virtual |
| ReadString(MemoryMappedViewAccessor accessor, long pos, int size) (defined in realvirtual.InterfaceSHMBaseClass) | realvirtual.InterfaceSHMBaseClass | protected |
| SHMName | realvirtual.SimulinkInterface | |
| Signals | realvirtual.SimulinkInterface | |
| SimulinkCycle (defined in realvirtual.SimulinkInterface) | realvirtual.SimulinkInterface | |
| SimulinkSpeed (defined in realvirtual.SimulinkInterface) | realvirtual.SimulinkInterface | |
| SimulinkStatus (defined in realvirtual.SimulinkInterface) | realvirtual.SimulinkInterface | |
| Status | realvirtual.SimulinkInterface | |
| UpdateSignals() (defined in realvirtual.SimulinkInterface) | realvirtual.SimulinkInterface | |
| WriteString(MemoryMappedViewAccessor accessor, string text, long pos) (defined in realvirtual.InterfaceSHMBaseClass) | realvirtual.InterfaceSHMBaseClass | protected |
