realvirtual.InterfaceSHMBaseClass Class Reference
Base class for all types of shared memory interfaces (even with different structure as simit like the plcsimadvanced interface. More...
Inheritance diagram for realvirtual.InterfaceSHMBaseClass:
| void | WriteString (MemoryMappedViewAccessor accessor, string text, long pos) |
| string | ReadString (MemoryMappedViewAccessor accessor, long pos, int size) |
| void | OnConnected () |
| void | OnDisconnected () |
| void | OnEnable () |
| void | OnDisable () |
| virtual void | OpenInterface () |
| virtual void | CloseInterface () |
| void | DeleteSignals () |
| bool | IsConnected |
