| CloseInterface() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | virtual |
| OpenInterface() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | virtual |
| ReadString(MemoryMappedViewAccessor accessor, long pos, int size) (defined in realvirtual.InterfaceSHMBaseClass) | realvirtual.InterfaceSHMBaseClass | protected |
| WriteString(MemoryMappedViewAccessor accessor, string text, long pos) (defined in realvirtual.InterfaceSHMBaseClass) | realvirtual.InterfaceSHMBaseClass | protected |
