Public Member Functions |
Static Public Member Functions |
Public Attributes |
Protected Member Functions |
List of all members
realvirtual.RoboDKInterface Class Reference
This is the first version of the RoboDK integration. More...
Inheritance diagram for realvirtual.RoboDKInterface:
| void | GetTargets () |
| Quaternion | GetRotationQuaternion (Mat mat) |
| Matrix4x4 | GetTRSFlipped (Mat rdkmat) |
| Vector3 | GetPosition (Mat rdkmat) |
| void | GetParams () |
| void | InitSignals () |
| void | StartProgramm () |
| void | StopProgramm () |
| void | StartProgramm (string programm) |
| void | SetSpeed () |
| void | DeleteSignals () |
| static Vector3 | GetAngles (Mat source) |
| string | RoboDKApplication |
| string | RobotDKFile |
| string | RobotName |
| string | RobotDKIP |
| bool | OpenRDKOnStart |
| float | RDKSimulationSpeed |
| string | RobotProgramm |
| bool | RunProgrammOnStart |
| bool | LoopProgramm |
| bool | ProgrammIsRunning |
| bool | StopProgrammOnUnityStop |
| GameObject | TargetPrefab |
| GameObject | DebugEndEffector |
| Vector3 | EffectorPos |
| Vector3 | EffectorRot |
| Vector3 | OrigRot |
| List< Drive > | Axis |
| List< float > | CurrentAxisPosition |
Public Attributes inherited from realvirtual.InterfaceThreadedBaseClass | |
| int | MinUpdateCycle |
| int | CommCycleMeasures |
| int | CommCycleNr |
| int | CommTimeMs |
| int | CommTimeMin |
| float | CommTimeMed |
| int | CommTimeMax |
| int | CommCycleMeasureNum |
| int | UpdateCycleMs |
| string | ThreadStatus |
| int | MinUpdateCycle2 |
| int | CommCycleNr2 |
| int | CommTimeMs2 |
| int | CommTimeMin2 |
| float | CommTimeMed2 |
| int | CommTimeMax2 |
| int | CommCycleMeasureNum2 |
| int | UpdateCycleMs2 |
| string | ThreadStatus2 |
| bool | NoThreading |
| bool | TwoThreads |
| bool | IsConnected |
| override void | CommunicationThreadUpdate () |
| override void | CommunicationThreadClose () |
Protected Member Functions inherited from realvirtual.InterfaceThreadedBaseClass | |
| virtual void | SecondCommunicationThreadUpdate () |
| virtual void | SecondCommunicationThreadClose () |
| void | OnConnected () |
| void | OnDisconnected () |
| void | OnEnable () |
| void | OnDisable () |
Still in Beta and some interactions from Unity side like showing Targets, following in Editmode... are missing.
◆ CloseInterface()
virtual |
Reimplemented from realvirtual.InterfaceThreadedBaseClass.
◆ CommunicationThreadClose()
protectedvirtual |
◆ CommunicationThreadUpdate()
protectedvirtual |
◆ OpenInterface()
virtual |
