WebSocket interface for Keba automation controllers using JSON message format. More...
| string | BaseUrl |
| Keba controller IP address or hostname. | |
| string | Username |
| Username for Keba controller login. | |
| string | Password |
| Password for Keba controller login. | |
| int | HttpPort |
| HTTP port for REST API authentication. | |
| int | WebSocketPort |
| WebSocket port for variable service. | |
| float | ConnectionTimeout |
| Connection timeout in seconds. | |
| List< string > | ImportRootPaths |
| Root paths to import variables from (e.g., "SYS", "PLC", "SYS.HW") | |
| bool | ImportRecursive |
| Import variables recursively from subdirectories. | |
| SignalDirection | DefaultSignalDirection |
| Default direction for imported signals. | |
| bool | UsePatternMatching |
| Use pattern matching to determine signal direction from variable name. | |
| List< string > | InputPatterns |
| Patterns to identify input signals. | |
| List< string > | OutputPatterns |
| Patterns to identify output signals. | |
| string | OutputTopicName |
| Topic name for subscribing to output variables (Keba→Unity) | |
| string | InputTopicName |
| Topic name for sending input variables (Unity→Keba) | |
| int | SubscriptionCycleTimeMs |
| Subscription update cycle time in milliseconds. | |
| int | WebSocketQueueSize |
| Current number of messages in receive queue. | |
| bool | UseOnChangeSubscription |
| Subscribe to variable changes instead of periodic updates. | |
| string | State |
| InterfaceState | state |
| new string | ErrorMessage |
| bool | IsReconnecting |
| int | InputSignals |
| int | OutputSignals |
| int | CommCycleMs |
| int | CycleCount |
| int | UpdateCycleMs |
| bool | AutoReconnect |
| bool | DebugMode |
| bool | IsConnected |
| void | DeleteSignals () |
| virtual async Task | EstablishConnection (CancellationToken cancellationToken) |
| Establishes connection to the external system. | |
| virtual async Task | CommunicationLoop (CancellationToken cancellationToken) |
| Main communication loop executed each cycle after connection is established. | |
| virtual void | CloseConnection () |
| Closes the connection to the external system. | |
| void | Start () |
| new void | OnEnable () |
| new void | OnDisable () |
| void | FixedUpdate () |
| virtual void | CopyPropertiesToThreadSafe () |
| void | OnConnected () |
| void | OnDisconnected () |
| int | privateCycleCount |
| int | privateCommCycleMs |
◆ BaseUrl
| string realvirtual.KebaInterface.BaseUrl |
◆ ConnectionTimeout
| float realvirtual.KebaInterface.ConnectionTimeout |
◆ DefaultSignalDirection
| SignalDirection realvirtual.KebaInterface.DefaultSignalDirection |
◆ HttpPort
| int realvirtual.KebaInterface.HttpPort |
◆ ImportRecursive
| bool realvirtual.KebaInterface.ImportRecursive |
◆ ImportRootPaths
| List<string> realvirtual.KebaInterface.ImportRootPaths |
◆ InputPatterns
| List<string> realvirtual.KebaInterface.InputPatterns |
◆ InputTopicName
| string realvirtual.KebaInterface.InputTopicName |
◆ OutputPatterns
| List<string> realvirtual.KebaInterface.OutputPatterns |
◆ OutputTopicName
| string realvirtual.KebaInterface.OutputTopicName |
◆ Password
| string realvirtual.KebaInterface.Password |
◆ SubscriptionCycleTimeMs
| int realvirtual.KebaInterface.SubscriptionCycleTimeMs |
◆ UseOnChangeSubscription
| bool realvirtual.KebaInterface.UseOnChangeSubscription |
◆ UsePatternMatching
| bool realvirtual.KebaInterface.UsePatternMatching |
◆ Username
| string realvirtual.KebaInterface.Username |
◆ WebSocketPort
| int realvirtual.KebaInterface.WebSocketPort |
◆ WebSocketQueueSize
| int realvirtual.KebaInterface.WebSocketQueueSize |
