| BaseUrl | realvirtual.KebaInterface | |
| CloseConnection() | realvirtual.FastInterfaceBase | protectedvirtual |
| CommunicationLoop(CancellationToken cancellationToken) | realvirtual.FastInterfaceBase | protectedvirtual |
| ConnectionTimeout | realvirtual.KebaInterface | |
| CopyPropertiesToThreadSafe() | realvirtual.FastInterfaceBase | protectedvirtual |
| DefaultSignalDirection | realvirtual.KebaInterface | |
| EstablishConnection(CancellationToken cancellationToken) | realvirtual.FastInterfaceBase | protectedvirtual |
| HttpPort | realvirtual.KebaInterface | |
| ImportRecursive | realvirtual.KebaInterface | |
| ImportRootPaths | realvirtual.KebaInterface | |
| InputPatterns | realvirtual.KebaInterface | |
| InputTopicName | realvirtual.KebaInterface | |
| OutputPatterns | realvirtual.KebaInterface | |
| OutputTopicName | realvirtual.KebaInterface | |
| Password | realvirtual.KebaInterface | |
| SubscriptionCycleTimeMs | realvirtual.KebaInterface | |
| UseOnChangeSubscription | realvirtual.KebaInterface | |
| UsePatternMatching | realvirtual.KebaInterface | |
| Username | realvirtual.KebaInterface | |
| WebSocketPort | realvirtual.KebaInterface | |
| WebSocketQueueSize | realvirtual.KebaInterface | |
