Orchestrates complex robotic motion sequences through target-based path planning with industrial interpolation modes. More...
| void | startPath () |
| Start the path. | |
| void | OnXRInit (GameObject placedobj) |
| Event called on Init in XR Space. | |
| void | OnXRStartPlace (GameObject placedobj) |
| Called when Path is starting to be placed in XR / VR Space. | |
| void | OnXREndPlace (GameObject placedobj) |
| Called when Path is stopped to be placed in XR / VR Space. | |
| void | StartDrivePTP (IKTarget target) |
| Starts to drive PTP to the target. | |
| void | OnTargetDelete (IKTarget target) |
| bool | DriveToTarget (IKTarget target) |
| Starts to drive to the target. | |
| void | AddTargetToPath () |
| float | SpeedOverride |
| Speed override for this path. | |
| bool | SetNewTCP |
| Set new TCP for this path. | |
| bool | DebugPath |
| Debug the path by drawing points in scene mode. | |
| bool | DebugBlending |
| Logs detailed blending state transitions to console for debugging jump issues. | |
| GameObject | TCP |
| bool | DrawPath |
| New TCP for this path. | |
| bool | DrawTargets |
| Draw the targets in the scene view. | |
| List< IKTarget > | Path |
| List of targets for the path. | |
| PLCOutputBool | SignalStart |
| Signal to start the path. | |
| bool | StartPath |
| Start the path on simulation start. | |
| bool | LoopPath |
| Loop the path after this path is ended. | |
| PLCInputBool | SignalIsStarted |
| Signal that the path is started. | |
| PLCInputBool | SignalEnded |
| Signal that the path is ended. | |
| IKPath | StartNextPath |
| Start this path after this path is ended. | |
| bool | PathIsActive |
| Is the path active? | |
| bool | PathIsFinished |
| Is the path finished? | |
| bool | LinearPathActive |
| Is the linear path active? | |
| float | LinearPathPos |
| Position of the linear path. | |
| IKTarget | CurrentTarget |
| Current target of the path. | |
| IKTarget | LastTarget |
| Last target of the path. | |
| int | NumTarget |
| Number of the current target. | |
| bool | WaitForSignal |
| Is the path waiting for a signal? | |
| RobotIK | RobotIK |
| RobotIK component - assigned robot to this path. | |
| Vector3 | LastPlannedPosition |
| Last planned position of the robot. | |
| Quaternion | LastPlannedRotation |
This professional component manages robot trajectories by sequencing multiple IK targets with configurable interpolation methods (PTP, linear), speed control, and signal integration. Essential for programming pick-and-place operations, welding paths, assembly sequences, and material handling in virtual commissioning.
Key Features:
- Linear (LIN) and Point-to-Point (PTP) interpolation modes per target
- Zone blending (Überschleifen): smooth transition to next target within a configurable radius
- Loop path support with optional blending on the last target
- Signal integration for start, end, and wait-for-signal coordination
- Pick-and-place integration via Fixer components on IKTarget
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/motion/robot-inverse-kinematics
◆ DriveToTarget()
| bool realvirtual.IKPath.DriveToTarget | ( | IKTarget | target | ) |
◆ OnXREndPlace()
| void realvirtual.IKPath.OnXREndPlace | ( | GameObject | placedobj | ) |
◆ OnXRInit()
| void realvirtual.IKPath.OnXRInit | ( | GameObject | placedobj | ) |
◆ OnXRStartPlace()
| void realvirtual.IKPath.OnXRStartPlace | ( | GameObject | placedobj | ) |
◆ StartDrivePTP()
| void realvirtual.IKPath.StartDrivePTP | ( | IKTarget | target | ) |
◆ startPath()
| void realvirtual.IKPath.startPath | ( | ) |
Start the path.
◆ CurrentTarget
| IKTarget realvirtual.IKPath.CurrentTarget |
◆ DebugBlending
| bool realvirtual.IKPath.DebugBlending |
◆ DebugPath
| bool realvirtual.IKPath.DebugPath |
◆ DrawPath
| bool realvirtual.IKPath.DrawPath |
Draw the path in the scene view
◆ DrawTargets
| bool realvirtual.IKPath.DrawTargets |
◆ LastPlannedPosition
| Vector3 realvirtual.IKPath.LastPlannedPosition |
◆ LastTarget
| IKTarget realvirtual.IKPath.LastTarget |
◆ LinearPathActive
| bool realvirtual.IKPath.LinearPathActive |
◆ LinearPathPos
| float realvirtual.IKPath.LinearPathPos |
◆ LoopPath
| bool realvirtual.IKPath.LoopPath |
◆ NumTarget
| int realvirtual.IKPath.NumTarget |
◆ Path
| List<IKTarget> realvirtual.IKPath.Path |
◆ PathIsActive
| bool realvirtual.IKPath.PathIsActive |
Is the path active?
◆ PathIsFinished
| bool realvirtual.IKPath.PathIsFinished |
◆ RobotIK
| RobotIK realvirtual.IKPath.RobotIK |
◆ SetNewTCP
| bool realvirtual.IKPath.SetNewTCP |
◆ SignalEnded
| PLCInputBool realvirtual.IKPath.SignalEnded |
◆ SignalIsStarted
| PLCInputBool realvirtual.IKPath.SignalIsStarted |
◆ SignalStart
| PLCOutputBool realvirtual.IKPath.SignalStart |
◆ SpeedOverride
| float realvirtual.IKPath.SpeedOverride |
◆ StartNextPath
| IKPath realvirtual.IKPath.StartNextPath |
◆ StartPath
| bool realvirtual.IKPath.StartPath |
◆ WaitForSignal
| bool realvirtual.IKPath.WaitForSignal |
