realvirtual.HMI_Value Class Reference
HMI element to display a float or int value. More...
Inheritance diagram for realvirtual.HMI_Value:
| override void | Init () |
Public Member Functions inherited from realvirtual.HMI | |
| TextMeshProUGUI | GetText (string objName) |
| Image | GetImage (string objName) |
| virtual void | CloseExtendedArea (Vector3 pos) |
| void | OnValueChanged () |
| Canvas | GetCanvas (GameObject HMIelement, ref RectTransform rectTransform) |
| void | OnTransformParentChanged () |
| void | UpdateUISkinParameter (RealvirtualUISkin skin) |
| string | Title |
| Title of the value. | |
| int | TitleFontSize |
| Font size of the title. | |
| bool | DisplayUnit |
| Display unit of the value. | |
| string | Unit |
| Unit of the value. | |
| int | UnitFontSize |
| Font size of the unit. | |
| int | ValueFontSize |
| Font size of the value. | |
| string | Format |
| Format for the float value. Default is F2. | |
| bool | FollowCamera |
| If true, the value will always face the camera. | |
| int | NumberDecimalPlaces |
| bool | ObjectTracking |
| If true, the value will be placed at the position of the object. | |
| GameObject | TrackedObject |
| Object to track. | |
| Vector3 | Offset |
| Offset of the value position to the tracked object. | |
| PLCOutputInt | SignalInt |
| PLC output for int values. | |
| PLCOutputFloat | SignalFloat |
| PLC output for float values. | |
Public Attributes inherited from realvirtual.HMI | |
| Color | Color |
| Color of the HMI element. | |
| Color | ColorMouseOver |
| Color of the HMI element when the mouse is over it. | |
| RealVirtualHMIEvent | EventOnValueChanged |
| Event that is triggered when the value of the HMI element changes. | |
| Image | bgImg |
◆ Init()
virtual |
Reimplemented from realvirtual.HMI.
◆ DisplayUnit
| bool realvirtual.HMI_Value.DisplayUnit |
◆ FollowCamera
| bool realvirtual.HMI_Value.FollowCamera |
◆ Format
| string realvirtual.HMI_Value.Format |
◆ ObjectTracking
| bool realvirtual.HMI_Value.ObjectTracking |
◆ Offset
| Vector3 realvirtual.HMI_Value.Offset |
◆ SignalFloat
| PLCOutputFloat realvirtual.HMI_Value.SignalFloat |
◆ SignalInt
| PLCOutputInt realvirtual.HMI_Value.SignalInt |
◆ Title
| string realvirtual.HMI_Value.Title |
Title of the value.
◆ TitleFontSize
| int realvirtual.HMI_Value.TitleFontSize |
◆ TrackedObject
| GameObject realvirtual.HMI_Value.TrackedObject |
Object to track.
◆ Unit
| string realvirtual.HMI_Value.Unit |
Unit of the value.
◆ UnitFontSize
| int realvirtual.HMI_Value.UnitFontSize |
◆ ValueFontSize
| int realvirtual.HMI_Value.ValueFontSize |
