realvirtual.FanucInterface Class Reference
Inheritance diagram for realvirtual.FanucInterface:
| void | DebugMessage (string message) |
Public Member Functions inherited from realvirtual.InterfaceThreadedBaseClass | |
| void | DeleteSignals () |
| string | Adress |
| List< Drive > | Drives |
| int | NumInputs |
| int | NumOutputs |
Public Attributes inherited from realvirtual.InterfaceThreadedBaseClass | |
| int | MinUpdateCycle |
| int | CommCycleMeasures |
| int | CommCycleNr |
| int | CommTimeMs |
| int | CommTimeMin |
| float | CommTimeMed |
| int | CommTimeMax |
| int | CommCycleMeasureNum |
| int | UpdateCycleMs |
| string | ThreadStatus |
| int | MinUpdateCycle2 |
| int | CommCycleNr2 |
| int | CommTimeMs2 |
| int | CommTimeMin2 |
| float | CommTimeMed2 |
| int | CommTimeMax2 |
| int | CommCycleMeasureNum2 |
| int | UpdateCycleMs2 |
| string | ThreadStatus2 |
| bool | NoThreading |
| bool | TwoThreads |
| bool | IsConnected |
| override void | CommunicationThreadUpdate () |
Protected Member Functions inherited from realvirtual.InterfaceThreadedBaseClass | |
| virtual void | CommunicationThreadClose () |
| virtual void | SecondCommunicationThreadUpdate () |
| virtual void | SecondCommunicationThreadClose () |
| void | OnConnected () |
| void | OnDisconnected () |
| void | OnEnable () |
| void | OnDisable () |
◆ CloseInterface()
virtual |
Reimplemented from realvirtual.InterfaceBaseClass.
◆ CommunicationThreadUpdate()
protectedvirtual |
Reimplemented from realvirtual.InterfaceThreadedBaseClass.
◆ OpenInterface()
virtual |
