| Adress (defined in realvirtual.FanucInterface) | realvirtual.FanucInterface | |
| CloseInterface() (defined in realvirtual.FanucInterface) | realvirtual.FanucInterface | virtual |
| CommCycleMeasureNum (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleMeasureNum2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleMeasures (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleNr (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommCycleNr2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMax (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMax2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMed (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMed2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMin (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMin2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMs (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommTimeMs2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| CommunicationThreadClose() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| CommunicationThreadUpdate() (defined in realvirtual.FanucInterface) | realvirtual.FanucInterface | protectedvirtual |
| DebugMessage(string message) (defined in realvirtual.FanucInterface) | realvirtual.FanucInterface | |
| Drives (defined in realvirtual.FanucInterface) | realvirtual.FanucInterface | |
| MinUpdateCycle (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| MinUpdateCycle2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| NoThreading (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| NumInputs (defined in realvirtual.FanucInterface) | realvirtual.FanucInterface | |
| NumOutputs (defined in realvirtual.FanucInterface) | realvirtual.FanucInterface | |
| OpenInterface() (defined in realvirtual.FanucInterface) | realvirtual.FanucInterface | virtual |
| SecondCommunicationThreadClose() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| SecondCommunicationThreadUpdate() (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | protectedvirtual |
| ThreadStatus (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| ThreadStatus2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| TwoThreads (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| UpdateCycleMs (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
| UpdateCycleMs2 (defined in realvirtual.InterfaceThreadedBaseClass) | realvirtual.InterfaceThreadedBaseClass | |
