Example Drive component demonstrating PrePost FixedUpdate event usage for precise timing control. More...
| void | PreFixedUpdate () |
| Called before Unity's FixedUpdate - validates inputs and prepares calculations IMPLEMENTS IPreFixedUpdate::PreFixedUpdate. | |
| void | PostFixedUpdate () |
| Called after Unity's FixedUpdate - processes physics results and updates outputs IMPLEMENTS IPostFixedUpdate::PostFixedUpdate. | |
| void | ShowTimingInfo () |
| float | TargetSpeed |
| Target speed in millimeters per second. | |
| float | Acceleration |
| Acceleration in millimeters per second squared. | |
| PLCInputFloat | PLCTargetSpeed |
| PLC input for target speed control. | |
| PLCOutputFloat | PLCCurrentSpeed |
| PLC output for current speed feedback. | |
| PLCOutputBool | PLCAtTarget |
| PLC output indicating target speed reached. | |
| bool | EnableDebugLogging |
| Enable debug logging for timing analysis. | |
◆ PostFixedUpdate()
| void realvirtual.ExampleDriveWithPrePostFixed.PostFixedUpdate | ( | ) |
Implements realvirtual.IPostFixedUpdate.
◆ PreFixedUpdate()
| void realvirtual.ExampleDriveWithPrePostFixed.PreFixedUpdate | ( | ) |
Implements realvirtual.IPreFixedUpdate.
◆ Acceleration
| float realvirtual.ExampleDriveWithPrePostFixed.Acceleration |
◆ EnableDebugLogging
| bool realvirtual.ExampleDriveWithPrePostFixed.EnableDebugLogging |
◆ PLCAtTarget
| PLCOutputBool realvirtual.ExampleDriveWithPrePostFixed.PLCAtTarget |
◆ PLCCurrentSpeed
| PLCOutputFloat realvirtual.ExampleDriveWithPrePostFixed.PLCCurrentSpeed |
◆ PLCTargetSpeed
| PLCInputFloat realvirtual.ExampleDriveWithPrePostFixed.PLCTargetSpeed |
◆ TargetSpeed
| float realvirtual.ExampleDriveWithPrePostFixed.TargetSpeed |
