Behavior model of an intelligent drive which is getting a destination and moving to the destination. More...
| void | CalcFixedUpdate () |
| float | TargetSpeed |
| float | Acceleration |
| float | CurrentPositionScale |
| Scale factor for the current position feedback. | |
| float | CurrentPositionOffset |
| Offset applied to position feedback in millimeters. | |
| bool | ScaleFeedbackPosition |
| If true, applies scale and offset to position feedback. | |
| PLCOutputFloat | SignalAcceleration |
| Acceleration of the drive in millimeters / second. | |
| PLCOutputFloat | SignalTargetSpeed |
| Target (maximum) speed of the drive in mm/ second. | |
| PLCInputFloat | SignalCurrentSpeed |
| Signal for current Drive speed in mm / second. | |
| PLCInputFloat | SignalCurrentPosition |
| Signal for current Drive positon in mm. | |
| PLCInputBool | SignalIsDriving |
| Signal is true if Drive is currently driving. | |
This component needs to have as a basis a standard Drive.
◆ CalcFixedUpdate()
| void realvirtual.Drive_Speed.CalcFixedUpdate | ( | ) |
◆ OnStartSim()
protectedvirtual |
◆ CurrentPositionOffset
| float realvirtual.Drive_Speed.CurrentPositionOffset |
◆ CurrentPositionScale
| float realvirtual.Drive_Speed.CurrentPositionScale |
◆ ScaleFeedbackPosition
| bool realvirtual.Drive_Speed.ScaleFeedbackPosition |
◆ SignalAcceleration
| PLCOutputFloat realvirtual.Drive_Speed.SignalAcceleration |
◆ SignalCurrentPosition
| PLCInputFloat realvirtual.Drive_Speed.SignalCurrentPosition |
◆ SignalCurrentSpeed
| PLCInputFloat realvirtual.Drive_Speed.SignalCurrentSpeed |
◆ SignalIsDriving
| PLCInputBool realvirtual.Drive_Speed.SignalIsDriving |
◆ SignalTargetSpeed
| PLCOutputFloat realvirtual.Drive_Speed.SignalTargetSpeed |
