Behavior model of an intelligent drive which is getting a destination and moving to the destination. More...
| float | Destination |
| float | Acceleration |
| float | TargetSpeed |
| float | CurrentPositionScale |
| Scale factor for the current position feedback. | |
| float | CurrentPositionOffset |
| Offset applied to position command and feedback in millimeters. | |
| bool | ScaleFeedbackPosition |
| If true, applies scale and offset to position feedback. | |
| PLCOutputFloat | SignalDestination |
| Destination position of the drive in millimeters. | |
| PLCOutputFloat | SignalAcceleration |
| Acceleration of the drive in millimeters / second. | |
| PLCOutputFloat | SignalTargetSpeed |
| Target (maximum) speed of the drive in mm/ second. | |
| PLCInputFloat | SignalIsAtPosition |
| Signal is true if Drive is at destination position. | |
| PLCInputFloat | SignalIsAtSpeed |
| Signal for current Drive speed in mm / second. | |
| PLCInputBool | SignalIsAtDestination |
| Signal if Drive is at Destination. | |
| PLCInputBool | SignalIsDriving |
| Signal is true if Drive is currently driving. | |
This component needs to have as a basis a standard Drive.
◆ OnStartSim()
protectedvirtual |
◆ CurrentPositionOffset
| float realvirtual.Drive_ContinousDestination.CurrentPositionOffset |
◆ CurrentPositionScale
| float realvirtual.Drive_ContinousDestination.CurrentPositionScale |
◆ ScaleFeedbackPosition
| bool realvirtual.Drive_ContinousDestination.ScaleFeedbackPosition |
◆ SignalAcceleration
| PLCOutputFloat realvirtual.Drive_ContinousDestination.SignalAcceleration |
◆ SignalDestination
| PLCOutputFloat realvirtual.Drive_ContinousDestination.SignalDestination |
◆ SignalIsAtDestination
| PLCInputBool realvirtual.Drive_ContinousDestination.SignalIsAtDestination |
◆ SignalIsAtPosition
| PLCInputFloat realvirtual.Drive_ContinousDestination.SignalIsAtPosition |
◆ SignalIsAtSpeed
| PLCInputFloat realvirtual.Drive_ContinousDestination.SignalIsAtSpeed |
◆ SignalIsDriving
| PLCInputBool realvirtual.Drive_ContinousDestination.SignalIsDriving |
◆ SignalTargetSpeed
| PLCOutputFloat realvirtual.Drive_ContinousDestination.SignalTargetSpeed |
