Marks a GameObject as a 3D visual sensor indicator for realvirtual WEB 3D-HMI. More...
| PLCOutputBool | SignalBool |
| Binary input: false=Low, true=High. Use for 2-state sensors. | |
| PLCOutputInt | SignalInt |
| Integer input: value mapped to state via IntStateMap. Use for 4+ state sensors. | |
| string | IntStateMap |
| Maps integer values to sensor states. | |
| string | Label |
| Optional label shown in WebViewer tooltip and sensor list. | |
UI-only marker for realvirtual WEB 3D-HMI. No Unity runtime function.
The WebSensor exposes four visual states — Low, High, Warning, Error — driven by up to one optional PLC signal. In the browser-based WebViewer the node (and all its mesh descendants) is rendered with a configurable gizmo overlay that switches color / opacity / blink-rate per state. All visual parameters are hardcoded in the WebViewer TypeScript layer — this component only provides the signal binding and an optional label.
Signal binding: use EITHER SignalBool (2-state: false=Low, true=High) OR SignalInt with IntStateMap for N-state mapping (default: 0=Low, 1=High, 2=Warning, 3=Error). If both are assigned, SignalInt wins.
Key Features:
- Four-state visual indicator (Low / High / Warning / Error) + Unbound fallback
- Bool or integer signal input with flexible int-to-state mapping
- ISA-101 aligned colors: grey / blue / amber (1 Hz blink) / red (2 Hz blink)
- Automatic export to GLB via rv_extras for WebViewer consumption
- Multi-mesh subtree handling: all child meshes render as one unit
- Optional label shown in WebViewer tooltip and sensor list panel
Common Applications:
- Status indicators on machines (on / running / warning / fault)
- Position sensors (end-of-travel, presence detection) visualization
- Alarm indicators on equipment with color + blink feedback
- Conveyor / line station status display in 3D HMI
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/webhmi/web-sensor
◆ IntStateMap
| string realvirtual.WebSensor.IntStateMap |
Leave empty for default (0=Low, 1=High, 2=Warning, 3=Error). Format: comma-separated "value:state" pairs, e.g. "0:low,1:high,5:warning,99:error". Values not listed map to 'Low' (with a one-time warning in the WebViewer console). Ignored when SignalBool is used.
◆ Label
| string realvirtual.WebSensor.Label |
◆ SignalBool
| PLCOutputBool realvirtual.WebSensor.SignalBool |
◆ SignalInt
| PLCOutputInt realvirtual.WebSensor.SignalInt |
Public Attributes inherited from
