realvirtual.UIMessage Class Reference
Modal UI Message box which can be opened by a PLC signal. Can be used for example for displaying warnings. More...
Inheritance diagram for realvirtual.UIMessage:
| void | OKPressed () |
| Close the message. | |
| void | enableMessage (bool enable) |
| Enable the message or disable the message. | |
Public Member Functions inherited from realvirtual.realvirtualUI | |
| void | SetColor (GameObject obj, Color color) |
| void | ResetColor (GameObject obj) |
| string | Header |
| The Header text of the message. | |
| string | Message |
| The message itself. | |
| float | AutoCloseAfterSeconds |
| Close the message after the defined time in seconds. If seconds is 0 the message is not automatically closed. | |
| GameObject[] | HightlightObjects |
| A collection of objects which should be highlighed during the message. | |
| float | HighLightRedCol |
| The highlight color in RGB - red. | |
| float | HighLightGreenCol |
| The highlight color in RGB - green. | |
| float | HighLightBlueCol |
| The highlight color in RGB - blue. | |
| float | FlashDuration |
| The duration of the highlight flash. | |
| bool | Display |
| Displays the message. | |
| PLCOutputBool | DisplayMessage |
| The PLCOutput signal which is connected to the message. | |
◆ enableMessage()
| void realvirtual.UIMessage.enableMessage | ( | bool | enable | ) |
◆ OKPressed()
| void realvirtual.UIMessage.OKPressed | ( | ) |
Close the message.
◆ AutoCloseAfterSeconds
| float realvirtual.UIMessage.AutoCloseAfterSeconds |
◆ Display
| bool realvirtual.UIMessage.Display |
◆ DisplayMessage
| PLCOutputBool realvirtual.UIMessage.DisplayMessage |
◆ FlashDuration
| float realvirtual.UIMessage.FlashDuration |
◆ Header
| string realvirtual.UIMessage.Header |
◆ HighLightBlueCol
| float realvirtual.UIMessage.HighLightBlueCol |
◆ HighLightGreenCol
| float realvirtual.UIMessage.HighLightGreenCol |
◆ HighLightRedCol
| float realvirtual.UIMessage.HighLightRedCol |
◆ HightlightObjects
| GameObject [] realvirtual.UIMessage.HightlightObjects |
◆ Message
| string realvirtual.UIMessage.Message |
The message itself.
