| AutoCloseAfterSeconds | realvirtual.UIMessage | |
| Display | realvirtual.UIMessage | |
| DisplayMessage | realvirtual.UIMessage | |
| enableMessage(bool enable) | realvirtual.UIMessage | |
| FlashDuration | realvirtual.UIMessage | |
| Header | realvirtual.UIMessage | |
| HighLightBlueCol | realvirtual.UIMessage | |
| HighLightGreenCol | realvirtual.UIMessage | |
| HighLightRedCol | realvirtual.UIMessage | |
| HightlightObjects | realvirtual.UIMessage | |
| OKPressed() | realvirtual.UIMessage | |
| ResetColor(GameObject obj) (defined in realvirtual.realvirtualUI) | realvirtual.realvirtualUI | |
| SetColor(GameObject obj, Color color) (defined in realvirtual.realvirtualUI) | realvirtual.realvirtualUI | |
