realvirtual.TwinCATHMIInterface Class Reference
TwinCAT HMI Interface which is communicating over WebSockets. Thus this interface also works in WebGL Builds. TwinCAT HMI Server needs to be installed on the PLC side for using this interface.
Inheritance diagram for realvirtual.TwinCATHMIInterface:
realvirtual.InterfaceBaseClass realvirtual.realvirtualBehavior
Public Attributes
string ServerAdress
- Public Attributes inherited from realvirtual.InterfaceBaseClass
bool IsConnected =false
List< InterfaceSignalInterfaceSignals = new List<InterfaceSignal>()
- Public Attributes inherited from realvirtual.realvirtualBehavior
string Name
 The name of the component if it should be different from the GameObject name.
ActiveOnly Active
GameObject FromTemplate
realvirtualController realvirtualController
bool HideNonG44Components
bool SceneIsAdditive
bool ForceStop = false
Additional Inherited Members
- Public Types inherited from realvirtual.realvirtualBehavior
enum  ActiveOnly
- Public Member Functions inherited from realvirtual.InterfaceBaseClass
void UpdateInterfaceSignals (ref int inputs, ref int outputs)
 Creates a new List of InterfaceSignals based on the Components under this Interface GameObject.
Signal CreateSignalObject (string name, SIGNALTYPE type, SIGNALDIRECTION direction)
 Create a signal object as sub gameobject.
Signal AddSignal (InterfaceSignal interfacesignal)
void RemoveSignal (InterfaceSignal interfacesignal)
virtual GameObject GetSignal (string name)
 Gets a signal with a name. More...
virtual void OpenInterface ()
virtual void CloseInterface ()
void SetAllSignalStatus (bool connected)
void DestroyAllSignals ()
void DeleteSignals ()
- Public Member Functions inherited from realvirtual.realvirtualBehavior
void SetForceStop (bool forcestop)
Vector3 DirectionToVector (DIRECTION direction)
 Transfers the direction enumeration to a vector.
DIRECTION VectorToDirection (bool torotatoin, Vector3 vector)
 Transfers a vector to the direction enumeration.
float GetLocalScale (Transform thetransform, DIRECTION direction)
List< BehaviorInterfaceConnectionUpdateConnectionInfo ()
List< SignalGetConnectedSignals ()
void SetVisibility (bool visibility)
 Sets the visibility of this object including all subobjects.
List< BehaviorInterfaceConnectionGetConnections ()
List< SignalGetSignals ()
GameObject GetChildByName (string name)
 Gets a child by name.
List< GameObject > GetChildsByName (string name)
 Gets all child by name.
GameObject GetChildByNameAlsoHidden (string name)
List< GameObject > GetAllMeshesWithGroup (string group)
List< GameObject > GetAllWithGroup (string group)
List< GameObject > GetAllWithGroups (List< string > groups)
List< GameObject > GetAllMeshesWithGroups (List< string > groups)
List< string > GetMyGroups ()
List< GameObject > GetMeshesWithSameGroups ()
List< GameObject > GetAllWithSameGroups ()
MeshRenderer GetMeshRenderer ()
 Gets the mesh renderers in the childrens.
void SetCollider (bool enabled)
 sets the collider in all child objects
void ErrorMessage (string message)
 Displays an error message.
void ChangeConnectionMode (bool isconnected)
void Log (string message)
 Logs a message.
void Log (string message, object obj)
 Logs a message with a relation to an object.
void Warning (string message, object obj)
 Logs a warinng with a relation to an object.
void Error (string message, object obj)
 Logs an error with a relation to an object.
void Error (string message)
 Logs an error.
GameObject DebugPosition (string debugname, Vector3 position, Quaternion quaternation, float scale)
 Displays a gizmo for debugging positions.
void SetFreezePosition (bool enabled)
 Freezes all child components to the current poosition.
virtual void AwakeAlsoDeactivated ()
- Static Public Member Functions inherited from realvirtual.realvirtualBehavior
static bool DirectionIsLinear (DIRECTION direction)
 Gets back if the direction is linear or a rotation.
- Protected Member Functions inherited from realvirtual.InterfaceBaseClass
void OnConnected ()
void OnDisconnected ()
- Protected Member Functions inherited from realvirtual.realvirtualBehavior
bool hidename ()
bool hideactiveonly ()
virtual void OnStop ()
virtual void OnStart ()
MU GetTopOfMu (GameObject obj)
 Gets the top of an MU component (the first MU script going up in the hierarchy)
void InitGame4Automation ()
 Initialiates the components and gets the reference to the realvirtualController in the scene.
virtual void AfterAwake ()
void Awake ()
