Active (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
ActiveOnly enum name (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
AddSignal(InterfaceSignal interfacesignal) (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | |
AfterAwake() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | protectedvirtual |
Awake() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | protected |
AwakeAlsoDeactivated() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | virtual |
ChangeConnectionMode(bool isconnected) (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
CloseInterface() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | virtual |
CreateSignalObject(string name, SIGNALTYPE type, SIGNALDIRECTION direction) | realvirtual.InterfaceBaseClass | |
DebugPosition(string debugname, Vector3 position, Quaternion quaternation, float scale) | realvirtual.realvirtualBehavior | |
DeleteSignals() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | |
DestroyAllSignals() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | |
DirectionIsLinear(DIRECTION direction) | realvirtual.realvirtualBehavior | static |
DirectionToVector(DIRECTION direction) | realvirtual.realvirtualBehavior | |
Error(string message, object obj) | realvirtual.realvirtualBehavior | |
Error(string message) | realvirtual.realvirtualBehavior | |
ErrorMessage(string message) | realvirtual.realvirtualBehavior | |
ForceStop (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
FromTemplate (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetAllMeshesWithGroup(string group) (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetAllMeshesWithGroups(List< string > groups) (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetAllWithGroup(string group) (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetAllWithGroups(List< string > groups) (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetAllWithSameGroups() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetChildByName(string name) | realvirtual.realvirtualBehavior | |
GetChildByNameAlsoHidden(string name) (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetChildsByName(string name) | realvirtual.realvirtualBehavior | |
GetConnectedSignals() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetConnections() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetLocalScale(Transform thetransform, DIRECTION direction) (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetMeshesWithSameGroups() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetMeshRenderer() | realvirtual.realvirtualBehavior | |
GetMyGroups() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetSignal(string name) | realvirtual.InterfaceBaseClass | virtual |
GetSignals() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
GetTopOfMu(GameObject obj) | realvirtual.realvirtualBehavior | protected |
hideactiveonly() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | protected |
hidename() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | protected |
HideNonG44Components (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
InitGame4Automation() | realvirtual.realvirtualBehavior | protected |
InterfaceSignals (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | |
IsConnected (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | |
Log(string message) | realvirtual.realvirtualBehavior | |
Log(string message, object obj) | realvirtual.realvirtualBehavior | |
Name | realvirtual.realvirtualBehavior | |
OnConnected() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | protected |
OnDisconnected() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | protected |
OnStart() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | protectedvirtual |
OnStop() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | protectedvirtual |
OpenInterface() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | virtual |
realvirtualController (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
RemoveSignal(InterfaceSignal interfacesignal) (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | |
SceneIsAdditive (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
ServerAdress (defined in realvirtual.TwinCATHMIInterface) | realvirtual.TwinCATHMIInterface | |
SetAllSignalStatus(bool connected) (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | |
SetCollider(bool enabled) | realvirtual.realvirtualBehavior | |
SetForceStop(bool forcestop) (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
SetFreezePosition(bool enabled) | realvirtual.realvirtualBehavior | |
SetVisibility(bool visibility) | realvirtual.realvirtualBehavior | |
UpdateConnectionInfo() (defined in realvirtual.realvirtualBehavior) | realvirtual.realvirtualBehavior | |
UpdateInterfaceSignals(ref int inputs, ref int outputs) | realvirtual.InterfaceBaseClass | |
VectorToDirection(bool torotatoin, Vector3 vector) | realvirtual.realvirtualBehavior | |
Warning(string message, object obj) | realvirtual.realvirtualBehavior | |
