Simulates a PLC-controlled CNC loading and unloading station with robotic handling. More...
| float | MachineCycleTime |
| Duration in seconds for the CNC machining operation cycle. | |
| bool | OnlyMachineControll |
| If true, only machine control is handled internally while rest is controlled by external PLC. | |
| string | RobotState |
| Current state of the robot (WaitingForLoading, LoadingMachine, etc.) | |
| string | EntryState |
| Current state of the entry conveyor system. | |
| string | MachineState |
| Current state of the CNC machine (Empty, Loading, Machining, etc.) | |
| string | ExitState |
| Current state of the exit conveyor system. | |
| bool | AutomaticMode |
| True when system is in automatic operation mode. | |
| PLCInputBool | OnSwitch |
| Main power switch input signal. | |
| PLCInputBool | EmergencyButton |
| Emergency stop button input signal. | |
| PLCInputBool | AutomaticButton |
| Automatic mode selection button input. | |
| PLCOutputBool | AutomaticButtonLight |
| Light indicator for automatic mode button. | |
| PLCInputBool | RobotButton |
| Manual robot operation button input. | |
| PLCOutputBool | RobotLight |
| Light indicator for robot button. | |
| PLCInputBool | ConveyorInButton |
| Manual entry conveyor operation button input. | |
| PLCOutputBool | ConveyorInLight |
| Light indicator for entry conveyor button. | |
| PLCInputBool | ConyeyorOutButton |
| Manual exit conveyor operation button input. | |
| PLCOutputBool | ConveyorOutLight |
| Light indicator for exit conveyor button. | |
| PLCOutputBool | StartLoadingProgramm |
| Output signal to start robot loading program. | |
| PLCOutputBool | StartUnloadingProgramm |
| Output signal to start robot unloading program. | |
| PLCInputBool | LoadingProgrammIsRunning |
| Input signal indicating robot loading program is active. | |
| PLCInputBool | UnloadingProgrammIsRunning |
| Input signal indicating robot unloading program is active. | |
| PLCOutputBool | StartMachine |
| Output signal to start the CNC machine operation. | |
| PLCOutputBool | MoveToolingWheel |
| Output signal to move the tooling wheel into position. | |
| PLCOutputBool | OpenDoor |
| Output signal to open the machine door. | |
| PLCInputBool | DoorOpened |
| Input signal indicating machine door is fully opened. | |
| PLCInputBool | DoorClosed |
| Input signal indicating machine door is fully closed. | |
| PLCOutputBool | StartMachining |
| Output signal to start the machining process. | |
| PLCInputBool | IsMachining |
| Input signal indicating machining operation is in progress. | |
| PLCInputBool | MachiningFinished |
| Input signal indicating machining operation has completed. | |
| PLCOutputBool | EntryConveyorStart |
| Output signal to start the entry conveyor belt. | |
| PLCInputBool | EntrySensorOccupied |
| Input signal indicating entry sensor detects a part. | |
| PLCOutputBool | ExitConveyorStart |
| Output signal to start the exit conveyor belt. | |
| PLCInputBool | ExitSensorOccupied |
| Input signal indicating exit sensor detects a part. | |
This component demonstrates a complete industrial automation cycle including material handling, CNC machining, and robotic load/unload operations. It simulates the PLC logic for coordinating between entry conveyor, robot, CNC machine, and exit conveyor systems.
Key Features:
- Automatic and manual operation modes with emergency stop functionality
- State machine control for robot, conveyor, and CNC operations
- Configurable machine cycle times and operation parameters
- Safety interlocks and proper door control sequences
- Physics-based timing that respects Unity's Time.timeScale
Common Applications:
- Virtual commissioning of CNC loading systems
- Training operators on automated machine tending
- Testing PLC logic before deployment
- Demonstration of industrial automation workflows
Integration Points:
- Works with PLCInputBool and PLCOutputBool signals for PLC integration
- Can operate standalone or with external PLC control
- Compatible with robot programming interfaces
- Supports emergency stop and safety systems
For detailed documentation see: https://doc.realvirtual.io/demos/cnc-loading
◆ AutomaticButton
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.AutomaticButton |
◆ AutomaticButtonLight
| PLCOutputBool realvirtual.PLCDemoCNCLoadUnload.AutomaticButtonLight |
◆ AutomaticMode
| bool realvirtual.PLCDemoCNCLoadUnload.AutomaticMode |
◆ ConveyorInButton
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.ConveyorInButton |
◆ ConveyorInLight
| PLCOutputBool realvirtual.PLCDemoCNCLoadUnload.ConveyorInLight |
◆ ConveyorOutLight
| PLCOutputBool realvirtual.PLCDemoCNCLoadUnload.ConveyorOutLight |
◆ ConyeyorOutButton
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.ConyeyorOutButton |
◆ DoorClosed
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.DoorClosed |
◆ DoorOpened
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.DoorOpened |
◆ EmergencyButton
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.EmergencyButton |
◆ EntryConveyorStart
| PLCOutputBool realvirtual.PLCDemoCNCLoadUnload.EntryConveyorStart |
◆ EntrySensorOccupied
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.EntrySensorOccupied |
◆ EntryState
| string realvirtual.PLCDemoCNCLoadUnload.EntryState |
◆ ExitConveyorStart
| PLCOutputBool realvirtual.PLCDemoCNCLoadUnload.ExitConveyorStart |
◆ ExitSensorOccupied
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.ExitSensorOccupied |
◆ ExitState
| string realvirtual.PLCDemoCNCLoadUnload.ExitState |
◆ IsMachining
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.IsMachining |
◆ LoadingProgrammIsRunning
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.LoadingProgrammIsRunning |
◆ MachineCycleTime
| float realvirtual.PLCDemoCNCLoadUnload.MachineCycleTime |
◆ MachineState
| string realvirtual.PLCDemoCNCLoadUnload.MachineState |
◆ MachiningFinished
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.MachiningFinished |
◆ MoveToolingWheel
| PLCOutputBool realvirtual.PLCDemoCNCLoadUnload.MoveToolingWheel |
◆ OnlyMachineControll
| bool realvirtual.PLCDemoCNCLoadUnload.OnlyMachineControll |
◆ OnSwitch
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.OnSwitch |
◆ OpenDoor
| PLCOutputBool realvirtual.PLCDemoCNCLoadUnload.OpenDoor |
◆ RobotButton
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.RobotButton |
◆ RobotLight
| PLCOutputBool realvirtual.PLCDemoCNCLoadUnload.RobotLight |
◆ RobotState
| string realvirtual.PLCDemoCNCLoadUnload.RobotState |
◆ StartLoadingProgramm
| PLCOutputBool realvirtual.PLCDemoCNCLoadUnload.StartLoadingProgramm |
◆ StartMachine
| PLCOutputBool realvirtual.PLCDemoCNCLoadUnload.StartMachine |
◆ StartMachining
| PLCOutputBool realvirtual.PLCDemoCNCLoadUnload.StartMachining |
◆ StartUnloadingProgramm
| PLCOutputBool realvirtual.PLCDemoCNCLoadUnload.StartUnloadingProgramm |
◆ UnloadingProgrammIsRunning
| PLCInputBool realvirtual.PLCDemoCNCLoadUnload.UnloadingProgrammIsRunning |
Public Attributes inherited from
