realvirtual.MaterialChanger Class Reference
MaterialChanger dynamically switches between two materials based on various trigger conditions. More...
Inheritance diagram for realvirtual.MaterialChanger:
| Material | MaterialOff |
| Material to display when the status is off. | |
| Material | MaterialOn |
| Material to display when the status is on. | |
| bool | StatusOn |
| Current status state that determines which material is displayed. | |
| bool | ChangeOnCollission |
| If set to true, material changes on collision events. | |
| Sensor | ChangeOnSensor |
| Sensor that triggers material changes when objects are detected. | |
| PLCOutputBool | ChangeOnPLCOutput |
| PLC output signal that triggers material changes. | |
Public Member Functions inherited from realvirtual.ISignalInterface | |
It can change materials based on collisions, sensor states, or PLC output signals, enabling visual feedback for status changes.
◆ ChangeOnCollission
| bool realvirtual.MaterialChanger.ChangeOnCollission |
◆ ChangeOnPLCOutput
| PLCOutputBool realvirtual.MaterialChanger.ChangeOnPLCOutput |
◆ ChangeOnSensor
| Sensor realvirtual.MaterialChanger.ChangeOnSensor |
◆ MaterialOff
| Material realvirtual.MaterialChanger.MaterialOff |
◆ MaterialOn
| Material realvirtual.MaterialChanger.MaterialOn |
◆ StatusOn
| bool realvirtual.MaterialChanger.StatusOn |
Public Attributes inherited from
