Adds buttons or Lights which can be connected to Signals tp a 3D scene. More...
| void | OnActivated () |
| Public method for activating the button or switch for custom developments. | |
| void | OnDeActivated () |
| Public method for deactivating the button or switch for custom developments. | |
| bool | On |
| Status On. | |
| bool | MouseDown |
| Mouse is down. | |
| bool | PLCOn |
| PLC Signal is ON. | |
| bool | Blocked |
| bool | Switch |
| true if interaction should work like a switch, if false it works like a button | |
| Material | MaterialOn |
| Material which should be used for the ON status of the Switch or Button. | |
| Material | MaterialOnMouseDown |
| Material which should be used on mouse down. | |
| Material | MaterialOnBlocked |
| Material which should be used if interaction is blocked by a PLCSignal. | |
| float | DurationMaterialOnBlocked |
| Duration of visual feedback with MaterialOnBlocked. If user is pressing button and it is blocked by PLC it will be visualized. | |
| Material | MaterialPLCOn |
| Material which should be used if PLC Output signal SignalOn is true. | |
| Light | LightOn |
| Optional light which is turned on on ON status. | |
| Light | LightPLCOn |
| Optional light which is turned on if PLC Output signal SignalOn is true. | |
| PLCInputBool | SignalIsOn |
| PLCInput if button or switch status is on. | |
| PLCOutputBool | SignalOn |
| PLCOutput to turn PLCOn Status on. | |
| PLCOutputBool | SignalBlocked |
| PLCOutput to block interaction with button. | |
◆ OnActivated()
| void realvirtual.Interact3D.OnActivated | ( | ) |
◆ OnDeActivated()
| void realvirtual.Interact3D.OnDeActivated | ( | ) |
◆ DurationMaterialOnBlocked
| float realvirtual.Interact3D.DurationMaterialOnBlocked |
◆ LightOn
| Light realvirtual.Interact3D.LightOn |
◆ LightPLCOn
| Light realvirtual.Interact3D.LightPLCOn |
◆ MaterialOn
| Material realvirtual.Interact3D.MaterialOn |
◆ MaterialOnBlocked
| Material realvirtual.Interact3D.MaterialOnBlocked |
◆ MaterialOnMouseDown
| Material realvirtual.Interact3D.MaterialOnMouseDown |
◆ MaterialPLCOn
| Material realvirtual.Interact3D.MaterialPLCOn |
◆ MouseDown
| bool realvirtual.Interact3D.MouseDown |
Mouse is down.
◆ On
| bool realvirtual.Interact3D.On |
Status On.
◆ PLCOn
| bool realvirtual.Interact3D.PLCOn |
PLC Signal is ON.
◆ SignalBlocked
| PLCOutputBool realvirtual.Interact3D.SignalBlocked |
◆ SignalIsOn
| PLCInputBool realvirtual.Interact3D.SignalIsOn |
◆ SignalOn
| PLCOutputBool realvirtual.Interact3D.SignalOn |
◆ Switch
| bool realvirtual.Interact3D.Switch |
