HMI element to display messages. More...
| void | Modify () |
| void | ClickQuitButtonReference () |
| void | ClickCancelButtonReference () |
| void | ShowMessage (bool state) |
| MessageTypes | MsgType |
| Type of message. | |
| bool | UseUserDefinedColor |
| if true, use user defined color of the message background | |
| Color | BackgroundColor |
| bool | UseUserDefinedIcon |
| if true, use user defined icon | |
| Sprite | MessageIcon |
| string | Text |
| text of the message | |
| int | SizeText |
| size of the text | |
| Color | FontColor |
| color of the text and icons | |
| bool | ShowTimeStamp |
| if true, show time stamp | |
| bool | Modal |
| if true, the message is modal | |
| int | MessageCheckTime |
| time in seconds to check if the message is still valid after canceling | |
| bool | CancelButton |
| if true, show cancel button | |
| bool | AcknowledgeButton |
| if true, show acknowledge button | |
| bool | ShowButton |
| if true, show information button | |
| bool | ForceAcknowledge |
| if true, the message has to be acknowledged by the user | |
| GameObject | MessageTriggeredObject |
| object which is activated when the message is shown | |
| GameObject | InformationTriggeredObject |
| object which is activated when the information button is pressed | |
| bool | Highlighting |
| if true, the defined objects is highlighted | |
| List< MeshRenderer > | HightlightedObjects |
| list of objects which are highlighted | |
| Material | HighlightMaterial |
| material for highlighting | |
| bool | FlickerEffectMaterial |
| if true, the highlighting material is flickering | |
| Material | FlickerMaterial |
| material for flickering | |
| float | FlickerTime |
| time for flickering | |
| PLCOutputBool | SignalMessage |
| PLC output for message. | |
| PLCInputBool | SignalAcknowledge |
| PLC input for acknowledge. | |
| PLCInputBool | SignalCancel |
| PLC input for cancel. | |
| Image | IconReference |
| TextMeshProUGUI | TextReference |
| Button | AcknowledgeButtonReference |
| Button | CancelButtonReference |
| Button | ShowButtonReference |
| DateTime | timeStamp |
| string | currentType |
| HMI_Tab | parentTab |
| Image | bgImg |
◆ AcknowledgeButton
| bool realvirtual.HMI_Message.AcknowledgeButton |
◆ BackgroundColor
| Color realvirtual.HMI_Message.BackgroundColor |
◆ CancelButton
| bool realvirtual.HMI_Message.CancelButton |
◆ FlickerEffectMaterial
| bool realvirtual.HMI_Message.FlickerEffectMaterial |
◆ FlickerMaterial
| Material realvirtual.HMI_Message.FlickerMaterial |
◆ FlickerTime
| float realvirtual.HMI_Message.FlickerTime |
time for flickering
◆ FontColor
| Color realvirtual.HMI_Message.FontColor |
◆ ForceAcknowledge
| bool realvirtual.HMI_Message.ForceAcknowledge |
◆ Highlighting
| bool realvirtual.HMI_Message.Highlighting |
◆ HighlightMaterial
| Material realvirtual.HMI_Message.HighlightMaterial |
◆ HightlightedObjects
| List<MeshRenderer> realvirtual.HMI_Message.HightlightedObjects |
◆ InformationTriggeredObject
| GameObject realvirtual.HMI_Message.InformationTriggeredObject |
◆ MessageCheckTime
| int realvirtual.HMI_Message.MessageCheckTime |
◆ MessageIcon
| Sprite realvirtual.HMI_Message.MessageIcon |
user defined icon
◆ MessageTriggeredObject
| GameObject realvirtual.HMI_Message.MessageTriggeredObject |
◆ Modal
| bool realvirtual.HMI_Message.Modal |
◆ MsgType
| MessageTypes realvirtual.HMI_Message.MsgType |
Type of message.
◆ ShowButton
| bool realvirtual.HMI_Message.ShowButton |
◆ ShowTimeStamp
| bool realvirtual.HMI_Message.ShowTimeStamp |
◆ SignalAcknowledge
| PLCInputBool realvirtual.HMI_Message.SignalAcknowledge |
◆ SignalCancel
| PLCInputBool realvirtual.HMI_Message.SignalCancel |
◆ SignalMessage
| PLCOutputBool realvirtual.HMI_Message.SignalMessage |
◆ SizeText
| int realvirtual.HMI_Message.SizeText |
size of the text
◆ Text
| string realvirtual.HMI_Message.Text |
text of the message
◆ UseUserDefinedColor
| bool realvirtual.HMI_Message.UseUserDefinedColor |
◆ UseUserDefinedIcon
| bool realvirtual.HMI_Message.UseUserDefinedIcon |
