realvirtual.HMI_Marker Class Reference
HMI element to display a marker. More...
Inheritance diagram for realvirtual.HMI_Marker:
| override void | Init () |
Public Member Functions inherited from realvirtual.HMI | |
| TextMeshProUGUI | GetText (string objName) |
| Image | GetImage (string objName) |
| virtual void | CloseExtendedArea (Vector3 pos) |
| void | OnValueChanged () |
| Canvas | GetCanvas (GameObject HMIelement, ref RectTransform rectTransform) |
| void | OnTransformParentChanged () |
| void | UpdateUISkinParameter (RealvirtualUISkin skin) |
| Material | ColorOn |
| Material to use when the signal is high. | |
| Material | ColorOff |
| Material to use when the signal is low. | |
| bool | ObjectTracking |
| If true, the marker will be placed at the position of the object. | |
| GameObject | TrackedObject |
| Object to track. | |
| Vector3 | Offset |
| Offset to the tracked object. | |
| GameObject | EnableGameObjectOnSignalTrue |
| Object to enable when the signal is high. | |
| GameObject | EnableGameObjectOnSignalFalse |
| Object to enable when the signal is low. | |
| PLCOutputBool | SignalBool |
| Signal to use for the marker. | |
Public Attributes inherited from realvirtual.HMI | |
| Color | Color |
| Color of the HMI element. | |
| Color | ColorMouseOver |
| Color of the HMI element when the mouse is over it. | |
| RealVirtualHMIEvent | EventOnValueChanged |
| Event that is triggered when the value of the HMI element changes. | |
| Image | bgImg |
◆ Init()
virtual |
Reimplemented from realvirtual.HMI.
◆ ColorOff
| Material realvirtual.HMI_Marker.ColorOff |
◆ ColorOn
| Material realvirtual.HMI_Marker.ColorOn |
◆ EnableGameObjectOnSignalFalse
| GameObject realvirtual.HMI_Marker.EnableGameObjectOnSignalFalse |
◆ EnableGameObjectOnSignalTrue
| GameObject realvirtual.HMI_Marker.EnableGameObjectOnSignalTrue |
◆ ObjectTracking
| bool realvirtual.HMI_Marker.ObjectTracking |
◆ Offset
| Vector3 realvirtual.HMI_Marker.Offset |
◆ SignalBool
| PLCOutputBool realvirtual.HMI_Marker.SignalBool |
◆ TrackedObject
| GameObject realvirtual.HMI_Marker.TrackedObject |
Object to track.
