Behavior model of a drive where the drive is exactly following the current given position of the PLC This is special useful for connecting motion controllers and robot controllers torealvirtual. More...
| void | CalcFixedUpdate () |
| float | Offset |
| Offset in millimeter which is added to the position signal. | |
| float | Scale |
| Scale factor which is scaling the position value. | |
| float | CurrentPositionScale |
| Scale factor for the current position feedback. | |
| bool | ScaleFeedbackPosition |
| If true, applies scale and offset to position feedback. | |
| PLCOutputFloat | Position |
| Signal (PLCOutput) for the defined position of the drive. | |
| PLCInputFloat | CurrentPosition |
| PLCInput for the current position of the drive (without offset and scaling) | |
◆ CalcFixedUpdate()
| void realvirtual.Drive_FollowPosition.CalcFixedUpdate | ( | ) |
◆ OnStartSim()
protectedvirtual |
◆ CurrentPosition
| PLCInputFloat realvirtual.Drive_FollowPosition.CurrentPosition |
◆ CurrentPositionScale
| float realvirtual.Drive_FollowPosition.CurrentPositionScale |
◆ Offset
| float realvirtual.Drive_FollowPosition.Offset |
◆ Position
| PLCOutputFloat realvirtual.Drive_FollowPosition.Position |
◆ Scale
| float realvirtual.Drive_FollowPosition.Scale |
◆ ScaleFeedbackPosition
| bool realvirtual.Drive_FollowPosition.ScaleFeedbackPosition |
