realvirtual.WebsocketRealtimeInterface Class Reference
Inheritance diagram for realvirtual.WebsocketRealtimeInterface:
| void | CheckInit () |
| void | InitAsServer () |
| void | InitAsClient () |
| void | DeleteSignals () |
| void | PostAllScenesLoaded () |
| void | SetCollider (bool enabled) |
| Logs a warinng with a relation to an object. | |
| new string | name |
| string | address |
| Name of the client. | |
| int | port |
| Address of the server. | |
| bool | connectOnPlay |
| Port of the server. | |
| bool | DebugMode |
| Connect to the server on play. | |
| WebSocketClientInstance | clientInstance |
| Debug mode writes debug and communication messages to the console | |
| WebSocketServerInstance | serverInstance |
| bool | isServer |
| bool | IsConnected |
| void | OnConnected () |
| void | OnDisconnected () |
| void | OnEnable () |
| void | OnDisable () |
◆ CloseInterface()
virtual |
Reimplemented from realvirtual.InterfaceBaseClass.
◆ OpenInterface()
virtual |
◆ address
| string realvirtual.WebsocketRealtimeInterface.address |
Name of the client.
◆ clientInstance
| WebSocketClientInstance realvirtual.WebsocketRealtimeInterface.clientInstance |
◆ connectOnPlay
| bool realvirtual.WebsocketRealtimeInterface.connectOnPlay |
Port of the server.
◆ DebugMode
| bool realvirtual.WebsocketRealtimeInterface.DebugMode |
◆ port
| int realvirtual.WebsocketRealtimeInterface.port |
