UDP communication interface for exchanging data with external applications via UDP protocol. More...
| void | Connect () |
| void | Disconnect () |
| void | FixedUpdate () |
| void | Update () |
| void | DeleteSignals () |
| int | RemoteListenPort |
| UDP port number on the remote machine where messages are sent. | |
| int | LocalListenPort |
| UDP port number on the local machine for receiving incoming messages. | |
| string | RemoteIPAdress |
| IP address of the remote machine to send UDP messages to. | |
| int | Inputs |
| Total number of INPUT signals configured (Unity to external application) | |
| int | Outputs |
| Total number of OUTPUT signals configured (external application to Unity) | |
| int | SendingMessageSize |
| Total size in bytes of the outgoing UDP message. | |
| int | ReceivingMessageSize |
| Total size in bytes of the incoming UDP message. | |
| bool | DebugMode |
| Enables detailed logging of sent and received UDP messages. | |
| string | SymbolTable |
| Path to the CSV symbol table file for automatic signal configuration. | |
| string | SplitChar |
| Character delimiter for separating CSV columns. | |
Public Attributes inherited from realvirtual.InterfaceThreadedBaseClass | |
| int | MinUpdateCycle |
| int | CommCycleMeasures |
| int | CommCycleNr |
| int | CommTimeMs |
| int | CommTimeMin |
| float | CommTimeMed |
| int | CommTimeMax |
| int | CommCycleMeasureNum |
| int | UpdateCycleMs |
| string | ThreadStatus |
| int | MinUpdateCycle2 |
| int | CommCycleNr2 |
| int | CommTimeMs2 |
| int | CommTimeMin2 |
| float | CommTimeMed2 |
| int | CommTimeMax2 |
| int | CommCycleMeasureNum2 |
| int | UpdateCycleMs2 |
| string | ThreadStatus2 |
| bool | NoThreading |
| bool | TwoThreads |
| bool | IsConnected |
| override void | CommunicationThreadUpdate () |
Protected Member Functions inherited from realvirtual.InterfaceThreadedBaseClass | |
| virtual void | CommunicationThreadClose () |
| virtual void | SecondCommunicationThreadUpdate () |
| virtual void | SecondCommunicationThreadClose () |
| void | OnConnected () |
| void | OnDisconnected () |
| void | OnEnable () |
| void | OnDisable () |
The UDPInterface enables bidirectional communication using UDP (User Datagram Protocol) for sending and receiving data between Unity and external applications like PLCs, SCADA systems, or custom tools. It supports automatic signal mapping from CSV symbol tables with byte-level data positioning.
Key Features:
- Bidirectional UDP communication with configurable ports
- CSV-based symbol table import for automatic signal configuration
- Supports BOOL, INT, REAL data types
- Automatic byte position calculation for signals
- Debug mode for message logging and troubleshooting
Signal Direction Mapping:
- INPUT signals: Unity → External application (sent on local port)
- OUTPUT signals: External application → Unity (received on remote port)
CSV Symbol Table Format:
- Column 1: Signal name
- Column 2: Data type (BOOL/INT/REAL/TEXT/STRING/WSTRING)
- Column 3: Direction (PLC_IN/PLC_OUT)
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/interfaces/udp-pro
◆ CloseInterface()
virtual |
Reimplemented from realvirtual.InterfaceThreadedBaseClass.
◆ CommunicationThreadUpdate()
protectedvirtual |
◆ OpenInterface()
virtual |
◆ DebugMode
| bool realvirtual.UDPInterface.DebugMode |
◆ Inputs
| int realvirtual.UDPInterface.Inputs |
◆ LocalListenPort
| int realvirtual.UDPInterface.LocalListenPort |
◆ Outputs
| int realvirtual.UDPInterface.Outputs |
◆ ReceivingMessageSize
| int realvirtual.UDPInterface.ReceivingMessageSize |
◆ RemoteIPAdress
| string realvirtual.UDPInterface.RemoteIPAdress |
◆ RemoteListenPort
| int realvirtual.UDPInterface.RemoteListenPort |
◆ SendingMessageSize
| int realvirtual.UDPInterface.SendingMessageSize |
◆ SplitChar
| string realvirtual.UDPInterface.SplitChar |
◆ SymbolTable
| string realvirtual.UDPInterface.SymbolTable |
