StartDriveOnCondition automatically starts a drive based on monitoring other drive positions or sensor states. More...
Public Types | |
| enum | Condition { Greater , Smaller } |
| bool | StartBasedOnOtherDrivesPositon |
| Enables starting this drive based on another drive's position. | |
| Drive | MonitoredDrive |
| The drive whose position is monitored for triggering conditions. | |
| Condition | ConditionToStartDrive |
| Condition type (Greater or Smaller) that triggers the drive start. | |
| float | StartOnPosition |
| Position value in millimeters that triggers the drive start. | |
| float | IncrementStartOnPositon |
| Value in millimeters to increment the trigger position after each activation | |
| float | CurrentStartOnPositon |
| Current trigger position in millimeters after increments | |
| bool | StartBasedOnSensor |
| Enables starting this drive based on a sensor state. | |
| Sensor | MonitoredSensor |
| The sensor whose state is monitored for triggering conditions. | |
| bool | StartOnSensorHigh |
| If set to true, starts when sensor is occupied; if false, starts when sensor is free. | |
| float | MoveThisDriveTo |
| Target position in millimeters to move the drive to when triggered. | |
| bool | MoveIncremental |
| If set to true, moves relative to current position; if false, moves to absolute position. | |
| float | CurrentTarget |
| Calculated target position in millimeters for the next movement. | |
It enables synchronization between drives by starting movement when specific conditions are met, such as another drive reaching a certain position or a sensor being triggered.
◆ ConditionToStartDrive
| Condition realvirtual.StartDriveOnCondition.ConditionToStartDrive |
◆ CurrentStartOnPositon
| float realvirtual.StartDriveOnCondition.CurrentStartOnPositon |
◆ CurrentTarget
| float realvirtual.StartDriveOnCondition.CurrentTarget |
◆ IncrementStartOnPositon
| float realvirtual.StartDriveOnCondition.IncrementStartOnPositon |
◆ MonitoredDrive
| Drive realvirtual.StartDriveOnCondition.MonitoredDrive |
◆ MonitoredSensor
| Sensor realvirtual.StartDriveOnCondition.MonitoredSensor |
◆ MoveIncremental
| bool realvirtual.StartDriveOnCondition.MoveIncremental |
◆ MoveThisDriveTo
| float realvirtual.StartDriveOnCondition.MoveThisDriveTo |
◆ StartBasedOnOtherDrivesPositon
| bool realvirtual.StartDriveOnCondition.StartBasedOnOtherDrivesPositon |
◆ StartBasedOnSensor
| bool realvirtual.StartDriveOnCondition.StartBasedOnSensor |
◆ StartOnPosition
| float realvirtual.StartDriveOnCondition.StartOnPosition |
◆ StartOnSensorHigh
| bool realvirtual.StartDriveOnCondition.StartOnSensorHigh |
Public Types inherited from
