realvirtual.ModbusInterface Class Reference
Modbus TCP/RTU interface for communication with industrial devices using the Modbus protocol. More...
Inheritance diagram for realvirtual.ModbusInterface:
| void | WriteValue (ModbusData data, object value) |
| object | ReadValue (ModbusData data) |
| virtual void | OpenInterface () |
| virtual void | CloseInterface () |
| void | DeleteSignals () |
| bool | status |
| bool | IsServer |
| string | ServerIPAdress |
| int | ServerPort |
| int | ConnectedClients |
| bool | IsConnected |
| void | OnConnected () |
| void | OnDisconnected () |
| void | OnEnable () |
| void | OnDisable () |
Supports both server (slave) and client (master) modes for flexible integration with Modbus networks. Enables reading and writing of coils, discrete inputs, holding registers, and input registers. Commonly used for connecting to PLCs, HMIs, drives, sensors, and other industrial equipment from various manufacturers. Configure as server to simulate a Modbus device or as client to connect to existing Modbus devices on your network.
