| CloseInterface() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | virtual |
| ConnectedClients (defined in realvirtual.ModbusInterface) | realvirtual.ModbusInterface | |
| IsServer (defined in realvirtual.ModbusInterface) | realvirtual.ModbusInterface | |
| OpenInterface() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | virtual |
| ReadValue(ModbusData data) (defined in realvirtual.ModbusInterface) | realvirtual.ModbusInterface | |
| ServerIPAdress (defined in realvirtual.ModbusInterface) | realvirtual.ModbusInterface | |
| ServerPort (defined in realvirtual.ModbusInterface) | realvirtual.ModbusInterface | |
| status (defined in realvirtual.ModbusInterface) | realvirtual.ModbusInterface | |
| WriteValue(ModbusData data, object value) (defined in realvirtual.ModbusInterface) | realvirtual.ModbusInterface | |
