MeasureForce measures forces and torques acting on Unity joints. More...
| Vector3 | Force |
| Current force vector in Newtons acting on the joint. | |
| Vector3 | Torque |
| Current torque vector in Newton-meters acting on the joint. | |
| float | AbsForce |
| Absolute magnitude of the force vector in Newtons. | |
| float | AbsTorque |
| Absolute magnitude of the torque vector in Newton-meters. | |
| PLCInputFloat | ForceX |
| PLC signal output for force X component in Newtons. | |
| PLCInputFloat | ForceY |
| PLC signal output for force Y component in Newtons. | |
| PLCInputFloat | ForceZ |
| PLC signal output for force Z component in Newtons. | |
| PLCInputFloat | ForceAbs |
| PLC signal output for absolute force magnitude in Newtons. | |
| PLCInputFloat | TorqueX |
| PLC signal output for torque X component in Newton-meters. | |
| PLCInputFloat | TorqueY |
| PLC signal output for torque Y component in Newton-meters. | |
| PLCInputFloat | TorqueZ |
| PLC signal output for torque Z component in Newton-meters. | |
| PLCInputFloat | TorqueAbs |
| PLC signal output for absolute torque magnitude in Newton-meters. | |
This component reads force and torque values from a joint component and outputs them through PLC signals. Useful for monitoring forces in mechanical simulations and detecting load conditions.
◆ AbsForce
| float realvirtual.MeasureForce.AbsForce |
◆ AbsTorque
| float realvirtual.MeasureForce.AbsTorque |
◆ Force
| Vector3 realvirtual.MeasureForce.Force |
◆ ForceAbs
| PLCInputFloat realvirtual.MeasureForce.ForceAbs |
◆ ForceX
| PLCInputFloat realvirtual.MeasureForce.ForceX |
◆ ForceY
| PLCInputFloat realvirtual.MeasureForce.ForceY |
◆ ForceZ
| PLCInputFloat realvirtual.MeasureForce.ForceZ |
◆ Torque
| Vector3 realvirtual.MeasureForce.Torque |
◆ TorqueAbs
| PLCInputFloat realvirtual.MeasureForce.TorqueAbs |
◆ TorqueX
| PLCInputFloat realvirtual.MeasureForce.TorqueX |
◆ TorqueY
| PLCInputFloat realvirtual.MeasureForce.TorqueY |
◆ TorqueZ
| PLCInputFloat realvirtual.MeasureForce.TorqueZ |
