Measure component for calculating and monitoring distances between GameObjects in real-time. More...
| void | DrawString (string text, Vector3 worldPos, Color? textColor=null, Color? backColor=null) |
| GameObject | MeasureFrom |
| The object from which the Distance between Pivot Points should be measured to this objects Pivot Point. | |
| Vector3 | Distance |
| The measured distance (read only) as Vector in World coordinates. | |
| float | DistanceAbs |
| The measured distance (read only) as absolute value in World coordinates. | |
| Vector3 | SetDistance |
| The distance that should be set when button Set Distance is pushed. | |
| bool | KeepSetDistance |
| True if the distance should be always kept as the value in SetDistance. | |
| bool | DisplayOnSelected |
| Display measurement in Scene window when selected. | |
| bool | DisplayAlways |
| Display measurement in Scene window always. | |
| bool | DisplayLine |
| Display a line between points. | |
| bool | DisplayAbs |
| Display the absolute value in Scene window. | |
| bool | DisplayVector |
| Display the vector in World coordinates in Scene window. | |
| bool | UseMillimeters |
| Use Millimeters on display and PLCSignal (1 Unity scale = 1000mm) | |
| float | PLCSignalOffset |
| Offset to the PLCSignal. | |
| PLCInputFloat | MeasuredDistance |
| The absolute distance as PLCInputFloat. | |
| PLCInputFloat | MeasuredDistanceX |
| The distance in World X coordinates as PLCInputFloat. | |
| PLCInputFloat | MeasuredDistanceY |
| The distance in World Y coordinates as PLCInputFloat. | |
| PLCInputFloat | MeasuredDistanceZ |
| The distance in World Z coordinates as PLCInputFloat. | |
Provides continuous distance measurement between pivot points with visual feedback in the Scene view. Supports both absolute and vector distance output, automatic position maintenance, and PLC signal integration for position feedback control.
◆ DisplayAbs
| bool realvirtual.Measure.DisplayAbs |
◆ DisplayAlways
| bool realvirtual.Measure.DisplayAlways |
◆ DisplayLine
| bool realvirtual.Measure.DisplayLine |
◆ DisplayOnSelected
| bool realvirtual.Measure.DisplayOnSelected |
◆ DisplayVector
| bool realvirtual.Measure.DisplayVector |
◆ Distance
| Vector3 realvirtual.Measure.Distance |
◆ DistanceAbs
| float realvirtual.Measure.DistanceAbs |
◆ KeepSetDistance
| bool realvirtual.Measure.KeepSetDistance |
◆ MeasuredDistance
| PLCInputFloat realvirtual.Measure.MeasuredDistance |
◆ MeasuredDistanceX
| PLCInputFloat realvirtual.Measure.MeasuredDistanceX |
◆ MeasuredDistanceY
| PLCInputFloat realvirtual.Measure.MeasuredDistanceY |
◆ MeasuredDistanceZ
| PLCInputFloat realvirtual.Measure.MeasuredDistanceZ |
◆ MeasureFrom
| GameObject realvirtual.Measure.MeasureFrom |
◆ PLCSignalOffset
| float realvirtual.Measure.PLCSignalOffset |
◆ SetDistance
| Vector3 realvirtual.Measure.SetDistance |
◆ UseMillimeters
| bool realvirtual.Measure.UseMillimeters |
