realvirtual.MQTTInterface Class Reference
MQTT interface for IoT and IIoT communication using the lightweight publish-subscribe messaging protocol. More...
Inheritance diagram for realvirtual.MQTTInterface:
| string | Broker |
| Adress of the MQTT Broker. | |
| bool | IsConnected |
| virtual void | OpenInterface () |
| virtual void | CloseInterface () |
| void | DeleteSignals () |
| void | PostAllScenesLoaded () |
| void | SetCollider (bool enabled) |
| Logs a warinng with a relation to an object. | |
| void | OnConnected () |
| void | OnDisconnected () |
| void | OnEnable () |
| void | OnDisable () |
Connects to MQTT brokers (Mosquitto, HiveMQ, AWS IoT, Azure IoT Hub) for cloud integration and distributed systems. Supports MQTT 3.1.1 and MQTT 5.0 protocols with WebSocket transport, TLS encryption, and username/password authentication. Ideal for Industry 4.0 scenarios, connecting shop floor equipment to cloud platforms and enterprise systems. Configure broker address, port, and security settings to establish communication with your MQTT infrastructure.
◆ Broker
| string realvirtual.MQTTInterface.Broker |
