realvirtual.Lamp Class Reference
Lamp component for creating visual status indicators in industrial automation simulations. More...
Inheritance diagram for realvirtual.Lamp:
| void | On () |
| Turns the lamp on. | |
| void | Off () |
| Turns the lamp off. | |
| Material | MaterialOff |
| Material for off state. | |
| Material | MaterialOn |
| Material for on state. | |
| bool | UseHalo |
| Use halo for lamp. | |
| float | Diameter |
| Diameter of lamp in mm. | |
| float | Height |
| Height of lamp in mm. | |
| float | LightRange |
| Light range of lamp in mms. | |
| bool | Flashing |
| True if lamp should be flashing. | |
| float | Period |
| Lamp fleshing period in seconds. | |
| bool | LampOn |
| PLCOutputBool | SignalLampOn |
| Lamp is on if true. | |
| PLCOutputBool | SingalLampFlashing |
Provides configurable signal lights with on/off states, flashing modes, and optional halo effects. Supports PLC control integration for dynamic status display and warning signals in HMI applications.
◆ Off()
| void realvirtual.Lamp.Off | ( | ) |
Turns the lamp off.
◆ On()
| void realvirtual.Lamp.On | ( | ) |
Turns the lamp on.
◆ OnStartSim()
protectedvirtual |
◆ Diameter
| float realvirtual.Lamp.Diameter |
◆ Flashing
| bool realvirtual.Lamp.Flashing |
◆ Height
| float realvirtual.Lamp.Height |
◆ LightRange
| float realvirtual.Lamp.LightRange |
◆ MaterialOff
| Material realvirtual.Lamp.MaterialOff |
◆ MaterialOn
| Material realvirtual.Lamp.MaterialOn |
◆ Period
| float realvirtual.Lamp.Period |
◆ SignalLampOn
| PLCOutputBool realvirtual.Lamp.SignalLampOn |
Lamp is on if true.
◆ UseHalo
| bool realvirtual.Lamp.UseHalo |
Use halo for lamp.
