Controls a boolean signal based on drive position ranges with support for wrapping drives. More...
Classes | |
| class | PositionArea |
| Represents a position area that controls the output signal. More... | |
| void | CalcFixedUpdate () |
| Called every physics frame by the Drive component to update the position switch logic IMPLEMENTS IDriveBehavior::CalcFixedUpdate. | |
| List< PositionArea > | Areas |
| List of position areas that control the output signal using OR logic. | |
| bool | InvertAreas |
| If true, areas define false zones instead of true zones (inverts the output) | |
| float | PositionOffset |
| Global offset in millimeters or degrees applied to drive position before area checking. | |
| PLCInputBool | OutputSignal |
| Output signal to PLC, true when position is in any area, or inverted if InvertAreas is true. | |
| Called when simulation starts - initializes component references and caches IMPLEMENTS BehaviorInterface::OnStartSim. | |
The Drive Position Switch component monitors the drive's position and sets a boolean output signal when the position is within defined ranges. Multiple areas use OR logic, meaning the signal is true if the position is in ANY area. The component fully supports wrapping drives (JumpToLowerLimitOnUpperLimit) with automatic position normalization and wrapped area detection.
Key Features:
- Multiple position areas with start and end positions in millimeters or degrees
- Single boolean output controlled by all areas using OR logic
- Global position offset with automatic wrapping for rotational drives
- Area inversion mode to define false zones instead of true zones
- Automatic detection of wrapped areas like 350-10 degrees on rotational drives
- Position normalization handles drives temporarily exceeding limits during wrapping
Common Applications:
- Position-based activation zones on conveyors or linear axes
- Angular zones on rotational tables or robotic joints with continuous rotation
- Safe zones or work zones in automated systems
- Multi-zone detection with single output signal for PLC integration
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/motion/drive-behavior
Class Documentation
◆ realvirtual::Drive_PositionSwitch::PositionArea
| class realvirtual::Drive_PositionSwitch::PositionArea |
◆ CalcFixedUpdate()
| void realvirtual.Drive_PositionSwitch.CalcFixedUpdate | ( | ) |
◆ OnStartSim()
protectedvirtual |
◆ Areas
| List<PositionArea> realvirtual.Drive_PositionSwitch.Areas |
◆ InvertAreas
| bool realvirtual.Drive_PositionSwitch.InvertAreas |
◆ OutputSignal
| PLCInputBool realvirtual.Drive_PositionSwitch.OutputSignal |
◆ PositionOffset
| float realvirtual.Drive_PositionSwitch.PositionOffset |
