realvirtual.Drive_MeasureSpeedPosition Class Reference
Behavior model of a cylinder movement which can be connected to a Drive. More...
Inheritance diagram for realvirtual.Drive_MeasureSpeedPosition:
| float | CurrentPositionScale |
| Scale factor for the current position feedback. | |
| float | CurrentPositionOffset |
| Offset applied to position feedback in millimeters. | |
| bool | ScaleFeedbackPosition |
| If true, applies scale and offset to position feedback. | |
| PLCInputFloat | Speed |
| PLCOutput for the speed of the drive in millimeter / second, can be scaled by Scale factor. | |
| PLCInputFloat | Accelaration |
| PLCInputFloat | Position |
The cylinder is defined by a maximum (MaxPos) and minimum (MinPos) position in millimeter
◆ Accelaration
| PLCInputFloat realvirtual.Drive_MeasureSpeedPosition.Accelaration |
◆ CurrentPositionOffset
| float realvirtual.Drive_MeasureSpeedPosition.CurrentPositionOffset |
◆ CurrentPositionScale
| float realvirtual.Drive_MeasureSpeedPosition.CurrentPositionScale |
◆ ScaleFeedbackPosition
| bool realvirtual.Drive_MeasureSpeedPosition.ScaleFeedbackPosition |
◆ Speed
| PLCInputFloat realvirtual.Drive_MeasureSpeedPosition.Speed |
