realvirtual.Drive_Gear Class Reference
Behavior model of a drive which is connected to another drive with a gear. More...
Inheritance diagram for realvirtual.Drive_Gear:
| void | CalcFixedUpdate () |
| Drive | MasterDrive |
| Master drive which is defining the position of this drive. | |
| float | GearFactor |
| Gear factor of the gear. | |
| float | Offset |
| Offset of the gear in millimeter. | |
All positions of the master drive are directly transfered with offset and gear factor to this drive. The formula is CurrentPosition = MasterDrive.CurrentPosition * GearFactor+Offset;
◆ CalcFixedUpdate()
| void realvirtual.Drive_Gear.CalcFixedUpdate | ( | ) |
◆ GearFactor
| float realvirtual.Drive_Gear.GearFactor |
◆ MasterDrive
| Drive realvirtual.Drive_Gear.MasterDrive |
◆ Offset
| float realvirtual.Drive_Gear.Offset |
