This drive is only for test purposes. It is moving constantly two erratic positions between MinPos and MaxPos. More...
| void | CalcFixedUpdate () |
| float | MinPos |
| Minimum position of the range where the drive is allowed to move to. | |
| float | MaxPos |
| Maximum position of the range where the drive is allowed to move to. | |
| float | Speed |
| Speed of the drive in millimeter / second. | |
| bool | Driving |
| Set to true if Drive should drive to erratic positions. | |
| bool | IterateBetweenMaxAndMin |
| If true, the drive will only iterate between MinPos and MaxPos. If false, the drive will iterate between random positions. | |
| PLCOutputBool | SignalEnable |
| If this signal is true, the drive will drive to erratic positions. If the signal is void it is always enabled. | |
◆ CalcFixedUpdate()
| void realvirtual.Drive_ErraticPosition.CalcFixedUpdate | ( | ) |
◆ OnStartSim()
protectedvirtual |
◆ Driving
| bool realvirtual.Drive_ErraticPosition.Driving |
◆ IterateBetweenMaxAndMin
| bool realvirtual.Drive_ErraticPosition.IterateBetweenMaxAndMin |
◆ MaxPos
| float realvirtual.Drive_ErraticPosition.MaxPos |
◆ MinPos
| float realvirtual.Drive_ErraticPosition.MinPos |
◆ SignalEnable
| PLCOutputBool realvirtual.Drive_ErraticPosition.SignalEnable |
◆ Speed
| float realvirtual.Drive_ErraticPosition.Speed |
